Dishwashers Logo
sarah b Posted on Jun 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hotpoint Aquarius error code a5 Problem - Dishwashers
ZJ Limited
Level 3:
  • Master 17,989 Answers
  • Posted on Jun 16, 2011
ZJ Limited
Master
Level 3:
Answers
17989
Questions
0
Helped
14450049
Points
60858
A05 - Pressure switch has not been reset
Check in the user guide the reset procedure (generally, just need disconnected of power few minutes).
Hope helps.
2helpful
Hotpoint aquarius dishwasher tablet dispenser not working
Clean it by running a cycle with hot water and 2 cups white vinegar, I suspect you have mineral deposits built up and causing it to stick closed and this causes the problem
My HOTPOINT Aquarius + super silent will not tumble dry. it starts off OK but then comes up with Error code F-13 can you tell me what this means
Hello
F 13 is a fault code for water supply,inlet valve or hose connections.
You may try unplugging the machine and plugging back in to reset.
Hotpoint washing machine, model WF630, Error F-03???
Error code F03 is indicating a problem with the wash thermistor, it could be open or short circuit.
Check connections on thermistor and heater element.
Hope this helps.
11helpful
3answers
Error code on my Hotpoint Aquarius WF240
my hotpoint Aquarius wf340 when switch on 5 secs later on/off button flashing along with mini load lights. could u tell me the error codes for this machine?
Error code f-01
This motor does not have brushes fitted, the error code F01 indicates that the motor triac has shorted, this is part of the electronics that control the motor, it could possibly require a new main pcb, and/or new motor. If it is under 5 years old, then you are better off contacting Hotpoint, and getting it done under the 5 year part guarantee.
Plz rate my solution.
Thanks.
2helpful
Error code f-01 on hotpoint washer dryer aquarius model wd 640
f-01 means there is a motor problem.
may be the motor and/or the circuit board that controls it.
AQUARIUS HOTPOINT WD440
How many times does it flash.
it still sounds like you have an obstruction in something.
3helpful
2answers
Hotpoint aquarius wf740
Sounds like water pressure could be low or inlet pipe is kinked.
F04: possible filling or water level problem. Check water inlet pipe (or shut-off valve), or the outlet pipe, or the pump or pump filter if accessible (check for blockages or foreign objects). Also could be the water valve solenoid weak, causing filling to be too slow.
F05: possible draining (pumping off) problem, check the pump filter, or pump, outlet pipe, or U-BEND.
Don't forget to rate!
1helpful
Hotpoint Aquarius Dishwasher DWF31
MY DISHWASHER TASTES OF SALT AFTER EVERY WASH .I HAVE RINSED IT THREW AND IT STILL THE SAME
Top Dishwashers Experts
Mike Cairns
Mike Cairns
