I have exactly the same problem with the D90. Have tried different memory cards but the problem continues. The battery is drained over night.
This may be that your memory card has a fault and the camera is trying to write to it.
Can you try another memory card?
Memory cards can develop faults.
A memory card format in the camera may help but this will wipe all your photos.
tried that...thanks...Nothing changed...camera works fine but if you leave battery in it will drain even when off....Hmmm
I am having the same problem. I thought i had bad batteries but it looks like this is the issue. I have used another card and still the light flashes with a card installed. any other ideas?
You could try a reset to see if that fixes it.
Hold down the +/- and
AF buttons (on the top next to the green dots) for a few seconds, and the D90 resets. The top
LCD then blinks to show it has finished. The reset changes some things so check the camera is back how you want it.
The Red indicator flashing in the Camera may be the Access Lamp or the Power Lamp. The Access Lamp is located below the Control buttons and the Power Lamp near to the power button. If the Access Lamp is flashing, it indicates that the Camera is accessing the Memory. Do not remove the Memory Stick or Batter while the Access Lamp is lit.
If the Power Lamp is flashing, it indicates that the Camera is turned on. If the Lamp is lit in Red it shows that the Battery is not having enough charge. Insert new batteries or charged Nickel-Metal Hydride batteries to resolve the issue.
You may also try power resetting the Camera. To power reset the Camera, remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally. If the issue persists, service may be required.
Thanks
