Don't know which model you have but I have the DF-280. I had the same issue many people are having (my unit would not power on). The power cord is fine as I've confirmed this with a digital voltmeter. Turns out this particular unit has a safety switch on the right side of the metal/plastic brain unit housing. The switch is underneath the plastic protrusion that is perpendicular (or at a right angle) to the detachable electric plug. You probably won't notice it unless you look for it. My guess is the switch became less sensitive with use and despite being properly mounted to the fryer base, the brain unit did not recognize that it is properly mounted to the fryer base and therefore would not turn on.
The easiest fix for this is to stuff a small piece of paper towel slightly into the slit where the switch is activated and then remount the brain unit onto the fryer base. Another option is to replace the switch or buy a whole new fryer. If your switch actually was the problem, it should now turn on and work properly as mine did. Hope this helps...
Hi there. Hi limit switch/ device on fryers acts as safety device. It cuts gas supply on burners when it is triggered by high oil temperature in case the temperature regulating device failed to avoid further damage on equipment, property or life. It is not advisable to operate the equipment with bypassed hi limit device. I suggest to have it replaced first before putting the fryer back in operation. For parts inquiry/ ordering, you can visit http://www.pitco.com Regards.
Check the continuity, flip the switch on and off using an ohmmeter, if the switch is ok, check the thermal fuse inside.(you have to open the unit) replace whatever is defective
i think that its is a hi limit switch to prevent a oil fire the fryers at kfc would dothis everyso often and it turned out tobe a bad logicalboard somewhere, check all valves and the switches on them to make sure that the fryer is aware when they are open or closed? let me know if you need more info
