Watches Logo
Posted on Jun 16, 2011
Cannot set time on my new Adidas Response ADP6005 watch. manual is useless in this regard
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 16, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4642
Points
41
Just talked to Adidas. Manual is wrong on this watch type. To change time: press top-left button "set/light" and hold till "light off" appears. Then, hit bottom-left button "mode," toggling until you reach the hours/minutes/etc. Use top-right and bottom-right buttons to change numbers as needed. Hit top-left "set/light" button when finished.
Anonymous
Level 1:
New Friend:
  • Posted on Sep 04, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4642
Points
Hold the set/light button until offset appears. Under that it will have a number and an h next to it. The h stands for hours. The startl/stop button and the lap/reset button are used to adjust that number. If your watch is two hours behind actual time, set that number to plus two. Set it to minus two if your watch is two hours fast.
2answers
I need to know how to set timer for Adidas Ad0297107
There is single manual for all adidas watches. You can find procedure for your watch.
ADIDAS-ORIGINALS-TIMEPIECES_CARE-MANUALS_EN.pdf (adidaswatches.com)
Adidas ADH 6123. How to set up time and date for my Adidas digital watch please?
It is a basic 4 button watch.
Care Instructions & User Manuals
Adidas Watches https://adidaswatches.com > care-instructions-user-man...
Please have a look at the following Care Instructions and User Manuals to get familiar with your watch and ensure correct usage and optimize longevity. Select ...
Dont know how to change time on adp1774 adidas watch (reponse). i have tried all buttons and button combinations
press and hold the set button, after that some of the digits are flashing, it means it can be set. the mode button is for next to be set and the start?lap and stop is use for adjustments. i hpoe i had been helped you with this solution.
I need to know how to set the time thanks
Go to "http://www.adidas.com/campaigns/watches_fw07/content/index.asp?str" choose language and read generic instruction manual to find the section that applies to your watch.
How do u set the time on a adidas peachtree watch
Put "adidas watches" into your search engine and select the adidas site.
On the left of the screen is a menu , select "instruction manuals" and instructions appear.
12helpful
2answers
How to set the time No instruction manual
First look for the set button then press it ,a long press and If it is blinking that's the time you to select the hour ,the minutes,the day/date,the alarms and the special features of your watch.The right button the up and down or for scrolling.Try all of this so your time will set.
Hope it may help you;
Regards;
VOTIT
Dont forget to rate:
7helpful
3answers
Adidas watch adp1059 missing instruction manual
hold set button(top left) in for two seconds until 'light 'displays,then press bottom left button(mode)to scroll though hours etc,(use right buttons to adjust)when finished press top left again
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
