Mutiple images
posted by mholtwi on Aug 20, 2008
Focused on one bright star, I'm getting three images. The central one is brighter but there is one above & one below. Treied it withanother bright star with same result. Can this be corrected?
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 22, 2008
Not Rated (0)
RickCrockett
Rank:Apprentice Apprentice
Rating: 92%, 2 votes
The problem could be a vitreal spartion in your eye. Whe looing at a bright star does the images appaer to remain in place when you twist your head around the eyepiece. Do others see the same thing???
If they do then it sounds like a cracked element. This can occur in the eyepiece if the scope has ever been turned to the sun.
Change the eyepiece and see if the problem goes away. If it doesn't then a chipped or cracked primary or secondary is suspect.
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Mutiple images:
I don't want to Accept this solution
Can you Help with these Telescopes problems?
Vivitar (1607225) Telescope
Hi my name is Ryan and the other i was reading the...
Hi my name is Ryan and the other day while I was putting...
poor hot water pressure from some faucets
I am using parts from your vivitar telescope for an...
need manual for vivitar 60050 telescope
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Top Repair Providers for
Cameras & Camcorders
(214) 650-6531
Digital Camera repair and sales.
Mikes digital camera repair
(888) 977-3765
Remote and Telephone Support for PC, Peripheral,...
Qresolve
X
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
