Nokia 6600 Logo
Anonymous Posted on Jun 16, 2011
I use Nokia 6600. I can't turn on my phone by pressing the switch on button. Is there any alternate key press? I replace the battery but still can't be turn on. If i plugged in the charger cable, the phone turn on and show the charging is in progress but still can't be turn on.
Anonymous
Level 2:
  • Expert 223 Answers
  • Posted on Jun 16, 2011
Anonymous
Expert
Level 2:
Answers
223
Questions
0
Helped
79748
Points
748
As you said me that your using Nokia 6600 you need to visit your nearest nokia service center there they will replace you switch but another one after that you wont face any problem .This may take few minutes.You can use your mobile if you follow this simple steps.Take a pen and press that switch on button from that pen try till it get switch on i have use this method went i faced that problem.Thanks for your question happy to help.
Anonymous
Level 2:
Novelist:
  • Expert 96 Answers
Anonymous
Expert
Level 2:
Novelist:
Answers
96
Questions
0
Helped
18874
Points
341
Theres no alternate switch for that phone, all you have to do is to change the switch button to a new one.
1 Related Answer
Anonymous
  • 93 Answers
SOURCE: I use Nokia 6600. I can't turn on my phone by
hi, its is possible that the ON key is faulty, all you need to do is to try open the phone and see if you can press the botton yourself or you try give it to some one that has the tools to open up the phone because that is the only way the phone can be turn on...
cheers
1helpful
How to format internal memory of Nokia asha 200 mobile phone
Switch off your phone
When switching off, press the call button + * + 3 key buttons all at once
when doing this, switch on the phone while pressing all the key buttons
Keep on pressing the key buttons until format settings appear
Remove your fingers from the buttons and wait for it to reach 100%
#Make sure that your phone has full battery, otherwise everything will go wrong
#Thats all
tip
Nokia formating tips
Nokia N72, N73, N81, N95, NSeries Mobile Phones. Method 1: Three Finger Reset for Nokia Phone 1. Switch off your Nokia phone.
2. Hold down the following three keys, Green (call answer button) * Key, and Number ‘3? key.
3. While holding these buttons, press the power button and switch on the phone.
4. Wait for message ‘Formatting’ to appear on the screen and release all keys once you see that message.
Method 2: Hard Format of Nokia Mobile Phone 1. Switch off your Nokia phone
2. Now Press following key sequence *#7370#
3. Enter Default lock code is 12345.
4. While holding these buttons, press the power button and switch on the phone.
5. Wait for message ‘Formatting’ to appear on the screen and release all keys once you see that message.
Method 3: Soft Reset of Nokia Mobile Phone 1. Switch off your Nokia phone
2. Now Press following key sequence *#7780#
Please Note: The Above Nokia Phone Formatting method will erase all your Phone data. So do backup before proceeding for Formatting
on Mar 10, 2010 • Cell Phones
I use Nokia 6600. I can't turn on my phone by pressing the switch on button. Is there any alternate keypress? I replace the battery but still can't be turn on. If i plugged in the charger cable,...
cheers
Jun 16, 2011 • Nokia 6600
My nokia n73 is very slow. i want to format it's phone memory. when i press code it ask for lockcode..i gave 12345 and 00000 but it didn't accept....wat should i do?? plz help
How to Format Nokia N72, N73, N81, N95, NSeries Mobile Phones. Method 1: Three Finger Reset for Nokia Phone
2. Hold down the following three keys, Green (call answer button) * Key, and Number '3? key.
4. Wait for message 'Formatting' to appear on the screen and release all keys once you see that message.
5. Wait for message 'Formatting' to appear on the screen and release all keys once you see that message.
4helpful
When making a call or answering a call the mobile battery level comes down and showing battery low and get switched off
I had the same problem.
If your battery is not a Original Nokia (Genuine) Battery,then you must replace it with a genuine Nokia battery.
If the problem remains,then you have to Reset your phone
How to do it :
*#7780# (*#rst0*) - This will soft reset your phone. It is different from *#7370# because all data, like contacts, calendar and notes, are not removed.
It will only reset the phone settings, such as profiles, themes and shortcuts.
The default lock code is 12345.(Read Method 3)
or try this(But it will fully format your phone)
Method 1:
1. Switch off your Phone.
2. Hold down the following three keys, Green (call answer button) * (Star) Key, and Number '3' key.
3. While holding The Three buttons, press the power button for switch on the phone.
4. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 2:
2. Now Press following key-*#7370#
4. While holding All of the buttons, press the power button for switch on the phone.
5. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 3:
Please Note:
The formatting method will erase all of your Phone data.
Please take a backup before you Format.
2answers
My n70 mobiles struked again and again so what can i do
first of all you need to backup all your data.Installed applications may get deleted by undergoing the following process.So,be warned !!
***best option***: do a software update.You can find all the necessary pc softwares from nokia's official website.You'll need the data cable that came with your handset.
alternate method 1 : press *#7370#
alternate method 2:
if that didn't worked,turn off the phone.remove the battery and leave for 1 min.Then re-insert the battery and press "power on button" WHILE pressing "green key(dial key)"+" star(*)key "+"number 3 key"
How to format n72 cellphone not memory card only cellphone?
How to Format Nokia N72 & NSeries Mobile Phones. Method 1: Three Finger Reset for Nokia Phone 1. Switch off your Nokia phone.
4helpful
2answers
How can me format my mobile telephone ? (Nokia N95 8GB)
How to Format Nokia N72, N73, N81, N95, NSeries Mobile Phones. Method 1: Three Finger Reset for Nokia Phone1. Switch off your Nokia phone.
Method 2: Hard Format of Nokia Mobile Phone1. Switch off your Nokia phone
Method 3: Soft Reset of Nokia Mobile Phone1. Switch off your Nokia phone
1helpful
L forgot lock code
You will need to format the phone.
Please Note: The Above Nokia Phone Formatting method will erase all your Phone data. So do backup before proceeding for Formatting.
4answers
Pls. help.!!how can i reformat my nokia 6600.?
To format your cell phone, you need to dial *#7370# and after it gets formatted then just switch off your cell phone and then when your phone gets completely switched off then press and hold the send key (green) and while holding the send key press * (star key) and then number pad key 3 (three) hold them simultaneously and switch your cell phone back on and keep holding those keys till it shows FORMATTING,,,,,,,,,,,,,,
Make sure that the battery is fully charged before proceeding.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
