Question about Bosch Exxcel WFX 3267 Front Load Washer
My Bosch Nexxt Front Load Washer doesn't complete the fully wash cycle some times. It first happened with when I washed my sister's family's wash. It kept stopping in the middle of the wash cycle, so we thought her clothes has too much soap. After reducing the soap it finished the wash cycle after 3-4 times. Now the same situation is happening with my wash load. What can be done to ensure the wash cycle completes instead of stopping in the middle of the wash cycle? It does this 3-4 times then it completes the wash cycle.
    Brigadier General:
  • 6,277 Answers
(no promises but it's worth trying this!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 16, 2011
SOURCE:
Bosch nexxt essence won't spin
Either a blocked filter or worn carbon brushes
Oct 11, 2017 | Bosch Nexxt Premium WFMC6400UC Front Load...
My bosch 100 nexxt will not spin or complete a full cycle
does it spin and no pump, or pump and no spin or neither does it come to end of normal wash and stop before spinning.
Dec 21, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Nexxt 100 series front load washer will not spin. The machine will go through the entire wash cycle from wash-rinse-spin-finish but does not spin. I tried a separate spin cycle and nothing happens....
Just going on these symptoms, you may need a new control/timer.
Inside the control /timer are electrical contacts, and when your machine gets to that part of the cycle, the contacts are not closing to allow the cycle to complete.
If you have circuit board, you will perhaps need a new one of those.
If you do not, probably a control/timer assembly.
If you type "SeasPartsDIrect" into you computer's search engine, and then type your complete model number into the blank when you are asked for it, you may look at the schematic and see whether you have a control / timer or a circuit board.
God bless your efforts.
Oct 08, 2017 | Bosch Nexxt 100 Series WFMC1001UC Front...
My front loader washer does not agitate during
It is possibly the motor brushes. worst case scenario is the motor complete.
Jul 05, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
You first of all need to check the pump filter.
This should be located at the botom front right of washer.
Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean.
The pump itself is directly behind the filter housing, check there is nothing stuck in the housing.
This should solve the prob.
Please leave feedback for my solution.
Thankyou.
Jan 11, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Nexxt 500 Series Front Loading Washer
The only way is to disonnect the device from the controller board.
Sep 12, 2009 | Bosch Classixx WVF 2402 Front Load...
Cycles take an exceedingly long time to complete
no, the problem is the the valve that stops water from draining is not working. or not shuting off all the way, water will try to fill but never does or does and leaks back out and try again. replace valve/pump, if you take it apart u will find your paperclip u left in u pocket
Sep 07, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
2007 Bosch Washer WFMC 3301
It may be possible that you are using too much soap. There is a turbidity sensor that checks for soap in the water. It will keep rinsing until it thinks the soap is gone. You did not state if you are ever able to complete an entire cycle or not. If the cycle never completes, it is possibly a problem with the main circuit board. Have you allowed the machine to complete a cycle?
May 18, 2008 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch Exxcel WFX 3267 Front Load Washer Logo
151 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
