Question about New Bright Toys
I have a Rumble Bee Remote Control Operated Truck. It was working just fine and then I just had it sitting on my shelf for about a year or two. Today I put in new batteries into the New Bright 6 V (1.5 * 4) battery chamber and my truck won't operate. Any clues as to what might have gone wrong? Is there a reset button on the remotes or cars.
SOURCE:
  • 161 Answers
SOURCE: Dynamite RC Truck (battery operated)
make sure the remote batteries are new.
Posted on Mar 26, 2009
  • 161 Answers
SOURCE: lost the 9.6 v battery charger for the remote control truc
I would try a Radio Shack dealer if you have one near you, as long as the electric rating is exactly the same as is the plug connection it should work fine.
Posted on Mar 30, 2009
  • 110 Answers
SOURCE: I bought the battery operated with remote control
hi, easy operation but first if the car is fairly new, call the company and ask their advise, cutting wires will probably void the warranty.
1.cut the wires and strip between the old battery and the car.
2. strip and connect the new battery by twisting together and securing with wire nuts available at any hardware store on the planet, like these
dpurlee_0.jpg 3. test the car, if it doesnt work correctly or at all, the + and - are probably reversed, switch and try again.
4. its a good idea to reenforce the wire nuts with duct or electrical tape after they are tightened.
good luck!
Posted on Feb 09, 2011
  • 3 Answers
SOURCE: The Wildfire rc monster truck
There may be a frequency setting on the remote control, the vehicle, or both. The switch typically looks the same as the On/Off switch only "A" and "B" would replace on and off. If the product has this feature, make sure that the switches on both items matches.
Posted on Jun 16, 2011
  • 28 Answers
SOURCE: remote control is messed up.
Dear Jereed7,
Have you tried to change the batteries of the controller?
When you haven't used it for two years, then i would try that in the first place.
I hope I helped you with your problem.
With kind regards,
MisterN
Posted on Aug 10, 2011
CD will not play. The CDs goes in and out fine and looks like it is playing according to the display. I can change songs, fast forward and reverse through the songs according to the display but nothing...
Do you have the radio hooked up to an amplifier? If so, it sounds like you are using the blue wire (antenna remote turn on) instead of the blue/white wire (amplifier remote turn on) to turn the amp on. The antenna remote wire turns off when leaving tuner mode.
Jun 22, 2011 | Alpine CDA-7863 CD Player
An Emerson T series 6volt,200AH,battery stored for
11% loss over 2wo years sounds pretty good to me. What is the electrolytic source? If it is NiCad, maybe not, but anything else should be fine.
Oct 21, 2009 | Emerson Fans Emerson SW102 White Battery...
I have 2 fans 1 stopped working 1 remote
Look at the remote code on the remote which is broken, then copy the code on the fixed remote, then you can control anoher fan.
Jul 12, 2009 | Universal Remote Control Hampton Bay...
Lost the 9.6 v battery charger for the remote control truc
Mar 29, 2009 | Toys
Transmission fluid capacity
Manual 6 quarts
Automatic depends on why it's being added. If bone dry try 8 quarts and check. Always check warm in no gear, if you can't be carefullllll not to over fill. Atf +4 is what dodge automatic. take
Aug 18, 2008 | 2005 Dodge Ram 1500
RCA RS2652 speaker rumble...
you can use wood glue and glue it back together thats what i did with mine and i havent had a problem since
Aug 07, 2006 | RCA RS2652 Shelf System
Toys Logo
Top New Bright Toys Experts
Colin Stickland
Colin Stickland
Jonah Oneal
gerry bissi
Are you a New Bright Toy Expert? Answer questions, earn points and help others
