Computers & Internet Logo
Posted on Jun 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I put my memory card into the Dynex reader and nothing is happening
Anonymous
Level 2:
New Friend:
  • Expert 88 Answers
  • Posted on Jun 16, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
88
Questions
Helped
31729
Points
209
Which operating system? Mac OS should mount the volume on the desktop when inserted, in Windows, you will have to open Computer/My Computer and access the drive letter it assigned to your card.
If nothing at all happens try a different USB port
the device is plug and play, it should "just work" hehe
Anonymous
Level 3:
Master:
  • Master 411 Answers
Anonymous
Master
Level 3:
Master:
Answers
411
Questions
0
Helped
67361
Points
1264
Move the reader to a different USB port. If that doesn't work, the reader's probably given it up. I've seen several of this brand reader die an early death, for no apparent reason.
Dynex DX-CR121 memory card reader not accepted by MAC laptop through USB
You need to put a card in the slot before it will mount to your Mac Desktop.
1helpful
Ok I was messing around on the computer with my sd chip in my dynex card reader and then I put my sd chip back into my Verizon cell phone and now the phone says I have no pictures saved on memory card so I...
Did you use the safely remove hardware icon your computer before you took the card out? Might be damaged.. copy them to your computer atleast, the card can be replaced if its bad.
How do i insert the 8b memory card in the memory card reader? i've tried it several ways and it does not light up??? i need a visual
The Dynex 5-in-1 Reader may be too old to read high capacity secure digital cards. (HCSD)
An 8 GB SD card is definitely going to be high capacity. Only the relatively newer SD readers can read the HCSDs.
Try putting in a 2 GB or lower size SD card and see if it works. If it does, then your card reader doesn't support higher capacity cards.
Good luck and thanks for using FixYa.
1helpful
How do you put music onto a memory card using a dynex memory card reader using a mac
Put the memory-card into the card-reader.
Connect the card-reader to the computer.
Watch the "desktop" for a new icon to appear, representing a "removable-disk-drive".
Double-click on the icon to open the folder.
Drag-and-drag music files from your computer into the folder that you just opened.
2answers
Windows 7 doesn't read my Dynex usb 2.0 card reader
1. You have to see if the program is compatible with the Windows 7 operating system.
this is possibly due to drivers that the Windows 7 doesn't have in the "cab" files.
this manufacturer of the Dynex is your next step for a Windows 7 driver set.
I cant figure out how to use the memory card reader, whenever I plug it into the computer nothing shows up. What do i do?
Make sure that the memory card is properly seated inside the card reader.
Try different cable.
Verify with the manufacturer, if this card reader is a Plug-n-Play or if you need to install a driver to the computer.
Try connecting it to different computer. Or try different types of memory cards (the cards should be supported).
If same problem occur, you need to contact the reseller, because the card reader could be defective.
Card reader installation!
The device wont be recognized by your computer until you insert a card. Plug a card into the reader, then plug the reader into the computer. You should hear a confirmation tone (if the card is formatted) and it should appear in my computer. No drivers or software are required as it uses a MSD (Mass Storage Device) interface.
Grand Canyon Tech
Grand Canyon Tech
