It sounds like you have entered a AUX mode this is when the device tried to find audio input (for example an ipod) look for a button called Function/input or radio
The power srouce is usaly locate at the back of the stero.. if it isnt.. its at the bottom. I would als try pluging it in.. and leaving it for a dayu... becuase maybe it charges
Yes it should be very easy with use of the ear phone jack - depending on the model of course but generally all you need is an ac/dc power supply, the antenna connection, and for connection to receiver you can connect via FM or hard wire.
FM: as in your car pick an FM station frequency that is clear (no station on it) lets say 88.1 then set your home receiver on 88.1 and there you have it.
DIRECT: purchase a stereo 3.5mm headphone cable with two RCA male plugs at the other end. A faily common cable found in dollar stores or for five times the price at Walmart/Radio Shack etc.. Plug the 3.5mm plug into the 'headpone' jack of the satellite radio and the RCA plugs into the rear of your home receiver - usually a 'aux/line in plug" or "tape in" plug then turn the knob on the receiver to "aux or tape" selector. Bingo you should hear satellite radio all over the house....if the volume is UP! Take care Frank
Note: This product is no longer available for purchase. It is presented here for access to support documentation, software and related accessories only.
It sounds like you are having a software programming problem and may need to return it wma capble features may be corrupt.
Hi
I'm not familiar with that particular model, but unless there is an input jack on the back, the note on the unit means that if you burn a cd on a computer,to play using this unit, you don't have to convert the songs to standard music format as you would with an older boombox, but you can leave them in MP3 format and fit many many songs on the CD, and the boombox will still play them.
So....You must burn the songs from your ipod to a cd, in MP3 format, and the box will play them.
Good Luck!
I have the same problem, when I contact Xact (through e-mail) they said that the unit would have to be replaced. They didn't say that THEY would replace it, but said it had to be replaced.
