Replace the pressure switch with generic switch available on ebay. You only need the port sizes and pressure cut in/out. If your switch cut out at 150psi or higher, you might consider replacing it with one that cuts out at 125psi to increase the life of the compressor (assuming that you can get by with pressure range of 90 - 125). Good luck
Excessive air pressure...if your safety valve is truely popping off, is caused by a bad pressure switch or a loose wire connection at the switch. It's a little odd to be leaking too. There is a couple a possibilities here. The most common spots for leakage is the "tube seal", the aluminum transfer/supply tube, or the outlet air hose. Usually a leak will keep a unit from acheiving full pressure causing the unit ot run continuously. The other common leakage spot is the "check valve" and a leak here usually makes the auto restart (upon using air from the tank, taking pressure below the set lower limit), not work,stalling the motor and popping a breaker. See ereplacementparts for a proper breakdown and identification of parts. Spliting the clamshell is a "pain in the neck" for these little units, but you"ll likely have to do that to find your internal leak. Carefully avoiding electrically exposed parts, spray a soapy water solution at suspected joints if the leak is not obvious.
This has been an issue for ALL Goldwing's (1000, 1100, 1200, 1500, and probably 1800's). It does not hurt anything. If you center stand you cycle it will never happen. but all Goldwing's are known to let out a puff of smoke if left on the side stand. The oil may be leaking past your piston rings and not your stem seals. If you want to change your stem seals you need to put the cylinder on top dead center compression stroke, remove the spark plug, screw in an air hose from your air compressor to pressurize your cylinder, with air pressure hold the valves in place compress the valve springs with a valve spring compressor, remove the parts (washer, cotter keys,and springs), pry off the seal, pop on the new one and reassemble. It is a lot easier living with the puff of smoke, Happy Trails.
From want you are describing sounds like the high pressure valves are leaking in the HP Head. there are 2 safeties on this unit . If the safety that's lifting is between the low and high pressure cylinders it's hp valves leaking. If the tank safety is lifting at 50-60 psi It should be replaced. It is a 200 psi safety.
Once the pop off valve reaches its opening point, it will stay open as long as the pressure is above that point. When you shut the compressor off, the pressure leaks down until the pop off valve closes. Sounds like the pressure regulator is set a little too high. If you can turn the regulator switch down, it should fix it.
