Hi
we have a Panasonic KX-T7433 Digital Super Hybrid System with around 120 extension numbers. Staff change their extension numbers from time to time and i need to know how i can change the name/extension number on my phone.
For example, Claire, who was on extension 3221 leaves the company and Mark is assigned her extension. How do i change the name on the phone so that when i dial 3221 it will say 'Mark' instead of 'Claire'?
thank you
I just worked it out.
Press Program
Then **
followed by your passcode (usually 1234)
Then 004
Then press next till you find Mark
Press Shift then the button under Clr
Then enter the name so for Claire start with 2 and swing the jog button round till you get a C, then press 5 and swing the jog button round till you get an l etc..
If you make a mistake press Transfer
Then when you've got your name correct press Auto Dial.
PROGRAMMING USER EXTENSION NAMES
Assigns a name to the extension numbers. Must
be done from main handset.
Enter programming mode
Press ‘Program’ and ‘**1234’ or ‘**0000’
To work out what jack number the handset is, if
you are using a display phone
Press ‘Program’ and ‘996’
This will bring up the jack number
Lift handset to cancel
Other than that if you know what name to replace
you can toggle through the names.
To Program
Enter ‘004’
Press ‘Next’
Enter the jack number
Press ‘Next’
Enter the name
If you need to delete or change a current entry
press ‘Clear’ then enter the new name
Press ‘Store’
To continue press ‘Next’ ‘Prev’ or ‘Select’
Repeat from entering the jack number
To finished press ‘End’
You need to find the mamager's phone, or have the installer access to the first phone in the system. Name changes are done from a programming command in the system.
Carl
Many staff members have come and gone and I need to change the names of the extensions on the phone; I have the main phone but I do not know how to access the system to change the after hour greeting or names the names.
change extension numbers on panasonic kxt7636
I am able to bring names up in the phone book but not the telephone numbers, unless you press to dial, that's when the number comes up. I wish to change a number as it has changed
