My nokia BH503 is not getting charged & countinuoisly blinking blue & not getting connected ..i got connected once ...after that it is not happening
RED indication light shows that the device needs charging.But if you think something is wrong with your headset a simple reset of your device could solve the problem.For resetting the device please follow the instructions below.
Clear the settings or resetting the headset
To clear the pairing and volume settings, switch off the headset, and press and hold the multifunction key and press the volume up key until the indicator light alternates red, green, and blue three times.
To reset the headset if it stops functioning, although it is charged, plug the charger into the headset, and press and hold the multifunction key and press the volume up key. The reset does not clear the headset settings.
Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks
TinuAlbinAlex
M unable to reset my bh-503 nokia by given procedure please help...
