SOURCE: brand new pentax E35
I find if you try to turn the camera on without any batteries in, or with them in the wrong way round (be careful!) then it jolts the camera into realising the battery situation has changed. So when you put in new batteries it bothers to "search" to see if there are new ones before giving out the "battery depleted" message. I spent over £20 on rechargeable and lithium batteries before I figured this out!
SOURCE: Digital camera
I had almost similar problems with my A10 from day one. The camera shuts down before the battery is depleted, most of the time while I was operating the zoomlens. I bought a new battery, but that didn't solve it. Later I decided to take it apart as a last option. As my suspicion was the zoomlens I took out two crews of the motor that operates it. Now the motor has a bit more space to move. It seemed to be too tight against the gears so it could cause an overload. After that it worked perfectly. I made pictures for hours without having the same fault again. Be carefull too make notes where all the tiny screws belong of the casing. And maybe it will be enough to just loosen the motorscrews, but leaving them out will not make it fall out of it's place. I hope someone can use this information.
Greetings, Ron Timmermans.
SOURCE: Pentax K10D won't work with lens from Pentax K100 (film0
The lenses are probably manual focus lenses,
Try this and everything should work fine.
If all this hasn't worked then try seting the mode dial on the camera to M manual mode.
Cheers
SOURCE: pentax service center in india
I want pentax service center in india at kolkata city ..... CAN YOU PLEASE HELP ME.........
