Archos Vision A14VG Digital Media Player Logo
Posted on Apr 04, 2017
My Archos Vision A14VG will not start. The battery is fully charged. The player is recognized by Windows XP when plugged in via USB cable (and the player power button is on). When connected to Windows XP I'm able to copy/paste/delete files no problem. In Windows, when I disconnect the USB device and then click the player's power/pause button, the main screen appears. I can use the 2 arrow buttons to navigate the main menu but clicking on the "select" button does not display the menus below/further down. When the USB cable is then unplugged the player goes off immediately and will not start up. Thanks very much in advance if you can help.
4 Related Answers
Anonymous
  • Posted on Oct 18, 2008
SOURCE: PC no longer recognizes my Archos 605
in the archos....select SYSTEM....change windows media player to PC Hard Drive and this worked for me
Anonymous
  • Posted on Nov 17, 2008
SOURCE: 605 wifi won't start
I was having a similar problem where my 160 gb Archos 605 would not hold a charge even after two days of being plugged in through an AC wall adapter. It worked fine for 5 months without a problem, but then all of the sudden it would not hold a charge even if the LED light was blinking green.
One thing that I found that makes it now hold a charge now is by letting is by plugging it in to a computer. I don't know why, but for some reason, now when I charge it through a computer usb as opposed to the wall adapter, it charges and holds a chrage for over 3 hours. So, maybe try to just let the thing charge through a computer.
Anonymous
  • 42 Answers
  • Posted on Sep 05, 2009
SOURCE: My archos wont connect to my computer
i had this problem. you have to use a high speed usb port (2.0 i think) which is normally in the back of your computer and then it should be detected
Anonymous
  • 318 Answers
  • Posted on Jun 24, 2011
SOURCE: please usb drv for
usbdrivers.net
1helpful
Not recognized by my laptop
Good morning, afternoon, evening or night; whatever time of day you are viewing this solution post. Thank you for choosing FixYa to assist you. Your computer is not recognizing your Archos Vision A14VG Digital Media Player? The computer should be able to recognize it because your digital media player is compatible with the three major operating systems: Windows, Mac and Linux. Maybe a Firmware or driver update will help.
  1. First, make sure your laptop has USB 2.0 hi-speed ports installed on it (If you are not sure if these are installed on your laptop, check your laptop's user manual).
  2. Connect your Archos to your laptop.
  3. On your laptop, go into Device Manager and expand the Universal Serial Bus Controllers group. Double click each device in that group until you find your digital media player.
  4. Update the driver.
  5. If it doesn't need an update, click try uninstalling the driver then reinstall it again.
If the computer still doesn't recognize your device, Try these websites to see if the device may need a firmware or driver update from there.
http://driverwhiz.com/drivers-en?brand=Archos&logo=Archos&subid=1001-us-en-10000048213&gclid=COOT2e-vgakCFYg32g but with with with oduyB-Sw
http://www.easydriverpro.com/lpd/drivers/drivers-en.php?sr=1&ci=500&agid=1349&ad=5825&kid=1349&gclid=COfRup-wgakCFcPt7QodeUzXTw
If your computer is still not recognizing it, try connecting your device to a desktop PC. If the desktop PC recognizes your device, then the problem is coming from the USB ports on your laptop. They may not have the amount of power needed for the device to connect to your laptop. If the PC desktop doesn't recognize the device, then the problem is that one of the drivers in the Archos is defective (not working anymore). Once that happens, the only way the device can work again is if the defective driver gets replaced. If your warranty for the product is still in effect, send the product back to its manufactuer and have them look at it. I hope this is just a driver updating issue. Thank you for choosing FixYa to assist you with your problem. Have a good day evening or night; whatever time of day you are viewing this.
How do i install into my PC
If you have a connection use a usb from the item to the computer, the computer should recognise your music player,
My daughter has an "Archos 3 cam vision MP4 player", and am unable to find the driver I need to use it. the Archos website asks about the product I have, but I do not know which one it is. I do...
Usually, just plugging in the mp3 player to the computer via usb cable will install the driver automatically on the computer. Make sure you have an internet connection on that computer you are connecting your mp3 player to.
Was there a CD with the mp3 player? If there was, the driver is probably there, and all you need to do is install the CD on your computer.
After searching the Archos website, I could not find the drivers for any of the mp3 players unfortunately. If the problem persists, you should tell Archos you have the "Archos 3Cam Vision Mp3 Player" as your product.
My archos vision 1 is not recognised by computer
Hi, archos vision 1 player not recognized by the computer
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see archos vision 1 player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the archos vision 1 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: archos vision 1 Players can connect to your computer in MSC or MTP mode. Exceptions are archos vision 1 Connect and archos vision 1 Express which only use MTP mode. MTP mode is the recommended and default method for archos vision 1 Players when used with Windows OS.
The archos vision 1 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Have a nice day....
I cannot accesss my archos av400 20GB via usb. I tried different cables. If I select Hard drive, windows dont detect my archos at all but when I select windows device, my windows detect the archos but not...
Your windows is installed on FAT 32 partition, so it is not recognized partitions bigger than 4 Gb. Change to NTFS. ATTENTION ! All informations on your computer will be lost. Do this only after saving your private files !!!
Archos won't connect by USB to computers
You should keep your eye on the device after its been plugged to the PC it will give you 2 options "charge" or "usb" you ca not establish a connection without picking usb connection option on the Archos screen when it pops up. If you are doing so and problem still existed then i would recommend you to download the latest windows media player. Because it comes with new devices sync driver update.
2answers
Archos 404 does not work at all since using Archos Docking Adaptor
You should try to only chare your Archos only when it is completely dead and charge it fully then the battery will be regular
2answers
Archos not recognised by both my computers
You must update the firmware on the archos.
Top Archos Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
