Question about Air Tools & Compressors
Where can i find ac motor connection diagrams, specifically, single phase forward and reverse, and 415v motor to 240v power diagrams? thanks andy
    Champion:
  • 205 Answers
There is no motor that is single phase with 415 volts only 240 volt or 120volt and you cannot use a 3 phase motor on single phase it will just fail to start buzz and burn it up .single phase motors have capacitors 3 phase motors do not
Posted on Jun 15, 2011
  • lbrunelli Aug 25, 2011
    Not all single phase motors are capacitor start, depends how they're wound
SOURCE:
How do you reverse a single phase 5 HP motor?
How do you reverse a single phase 5 HP motor check it on YouTube will give you the answer
Oct 18, 2018 | HP Air Tools & Compressors
Tip
How to Reverse the Rotation of Single Phase Capacitor-Start Electric Motors
Reversing the rotation of electric motors can be done easily with 3-phase motors. This can be easily achieved by swapping the connection of any two motor leads. But 3-phase motors are usually found and used for industrial purposes. The ones found and used in our homes, from water pumps to electric fans, are single phase capacitor-start type motors. Unlike 3-phase motors, reversing the rotation of single phase electric motors is no easy task. Swapping any two motor leads will not result in the reversal of the motor rotation. Analysis of the motor windings and connections are necessary before any modification can be done to achieve the desired result. Let's take a 3-speed single phase capacitor-start electric motor with electrical diagram shown below as an example. Make sure the motor is disconnected from the power supply before attempting to follow this tip. This tip is intended only for individuals with electrical knowledge, necessary tools, and understand the risks associated with handling electrical equipments and devices.
The first step in the process is determining the start winding which is connected to the line (AC white) and to one side of the start capacitor. To accurately determine the start winding, disconnect all motor leads from the start capacitor and the speed switch for multi-speed motors and then setting your ohmmeter to the lowest scale (R x 1), measure the resistances between the AC white line and each of the motor leads connecting to the start capacitor. The one with the least resistance is the starting winding lead.
Once the start winding lead going to the capacitor is determined, reconnect the capacitor then connect the black AC line to the found start winding lead (marked X). Connect the white AC line to L of speed switch, the motor lead formerly connected to AC white to 3, red to 2, and white to 1 as shown below. Leave the green/yellow ground wire connection as is.
Below are the wiring modifications for 2-speed and single speed single phase capacitor-start electric motors.
on Jan 11, 2011 | Dryers
LP126HD3A rated for 265 volts AC single phase I have 240V ac single phase, how can I use this unit on 240V ac
You'd need to supply a "Buck-Boost" transformer to do this properly. Technically, the 265 VAC is one hot leg and neutral of a 480 VAC 3 Phase Y system that measures 277 VAC. The 265 number comes from this:
265 is the standard nameplate voltage for a 277 volt motor or AC unit.
230 is standard name plate for 240.
200 is standard name plate for 208
460 is standard name plate for 480.
110 is standard name plate for 120.
Most electricians call the hot leg / neutral circuit "277V AC".
Some popular "Buck-Boost" transformers will convert 208 to 240 and 240 to 208 volt systems, and 240 to 277 and 277 to 240 volt systems - among many other variations. These are auto-transformers as the primary secondary windings share a connection. KVA ratings differ significantly from name plate because of this fact. You should contact a qualified electrician to not only size, but wire the transformer for you. Failure to install a Buck-Boost transformer - and running this unit on 240V AC mains will cause premature failure of motors - fans and compressor due to overheating. This can also result in a fire hazard.
I hope this helps and good luck!
Sep 06, 2011 | LG LP126HD3A Air Conditioner
I need a three phase wiring diagram for 8145-20 model timer.
8145-20 240Volt Paragon timer is not 3-phase.
Clock motor is 240V.
You need a transformer to convert 3-phase to single phase 240V to operate timer.
Then timer outputs can control 3-phase power using 3-phase contactors
Contactor below is 3 phase with 240V coil
http://www.grainger.com/Grainger/DAYTON-Contactor-2UTP7?Pid=search
Defrost timer wiring diagrams show below:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
Dec 21, 2010 | Paragon 8145-20 Defrost Timer
Taking my P660 out out a building with 3 phase power and into one with only single phase. Converter says motor will run on 2/3 power. Good or bad idea????
Good!
MOTOR:
21?2 H.P., Hobart designed, high torque ball bearing,
ventilated within mixer enclosure. Single-phase is
capacitor-start, induction-run type.
Three-phase is
polyphase squirrel cage, induction-run type.
Single Phase 208V 20.0 Amps
240V 17.0 Amps
Three Phase 208-240V 8.6 Amps
Nov 26, 2010 | Hobart P660 Stand Mixer
How do I connect multiple (two or more) 3 phase ac power sources (from wind turbine alternators) to a single 3 phase junction to power one device?
what did you mean by single 3 phase? single phase motor have two wire output 110-110, 3 phase gen have 3 wires 110-110-110. if only two wires here ,this is single phase, all appliances are only single phase so you can connect it here, except some 3 phase motor or dynamo. the ac current has no polarity so you can connect to it all kinds of load depends upon the amperage of of your turbine generators
Jul 22, 2010 | Kitchen Ranges
Need to install power cord to terminals on 220 AC motor
Ok, read the data plate on the motor. Does it have a zero with a line straight through it. That means it's single phase. Also the plate may list two different voltages 110/220ac correct. On the inside of the panel of the box where the cord connects it will have a two diagrams. One marked low voltage, the other high voltage. You want 220ac so follow the high voltage diagram. Since it's single phase the green wire will go to a green screw in the box. The black wire from your cord is positive and the white negitive (actually neutral but shown on diagrams as negitive). The wire coming out of the motor will have numbers on it's casing. Follow the connection points on the diagram. Don't worry if you hook them backwards the motor just won't turn. It won't hurt anything.
Apr 02, 2009 | Coleman Powermate 60 Gallon Air Compressor
Using dryer in 220V country
There are two systems in use in the states
110v dryers are available that fit a standard 11v 15a socket
110/220v fit the oversize 'dryer' sockets, and they are two 110v phases 90 degreees apart
the motor runs of a single phase 110v.
there is 220v between the 'outside', the active lines of the two phases, at any time, but it is not useable to provide mechanical power as a single service, due to the complicated shape of the wave form when you add out of phase voltages together, but is ok to drive the heaters, they have no mechanical efficiency requirement
A 2 phase 110v heater it means 3kw can be supplied without a 30 amp circuit
but it becomes difficult to use a single phase 220-240v transformer to provide 2x110v 90degree 2 phase current unless you specially buy one in. .
High power applications in 220-240v are generally supplied by 415v 3 phase 60deg supplies,
Any transformer would be onsellable at the end of your posting, to your replacement, who would doubtless be in the same boat as you, with a heap of 'stuff' that needs to run.
UK Aus NZ may be sources of transformers, or dryers to suit.
check with Australian UK NZ suppliers as well as local Indian ones, as those countries are also nominal 240v single phase home suplies and they may have (1) the dryer, or (2)the transformer to suit the 110 2 phase dryer
Sep 10, 2008 | Kenmore 62602 Electric Dryer
Wire up a 3 phase motor to single phase 240v power
3ph motors will only run on 3ph power, trying to single phase will only burn up windings,
Dec 12, 2007 | Heating & Cooling
Air Tools & Compressors Logo
468 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Marvin
Marvin
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
