Scanning Methods
You can select from the various scanning methods.
>If You Want to Edit or Print the Scanned images MP Navigator EX enables you to edit the scanned images, such as optimizing or trimming. You can also start application software from MP Navigator EX to edit or print the scanned images. For detailed operations of MP Navigator EX, refer to the Scanning Guide on-screen manual. You can also use the Operation Panel to open MP Navigator EX as well as open it using the computer.
>If You Want to Scan Originals with Advanced Settings ScanGear enables you to scan originals with advanced settings such as the resolution. For detailed operations of ScanGear, refer to the Scanning Guide on-screen manual.
Besides the above-mentioned methods, you can use a TWAIN- or WIA- (Windows Vista and
Windows XP only) compliant application software and the Control Panel (Windows Vista and
Windows XP only) to scan originals with this machine. For detailed operations, refer to the
>Opening MP Navigator EX using the Operation Panel
>>(Macintosh only) Prepare your computer before scanning. This operation is not necessary for Mac OS X v.10.4.x.User's Guide on-screen manual.
>>Turn on the machine.
>>Load the original document on the Platen Glass or the ADF.
>>Press the SCAN button, then press the Color or Black button.
I found these directions from your
Canon PIXMA MX310 User's Manual online (page 24). Other functions are available for reading.
To make sure you have got the correct program that you are using, uninstall all associated programs from your computer thru "Programs and Features" that can be found in Control Panel. Then, you may download your printer's drivers and softwares thru this
LINK. Make sure to download the appropriate version for your Windows.
NOTE: Keep in mind that the drivers and softwares are limited to the manufacturer's release.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
