Your LCD/monitor is cracked from the inside. There are several things that can cause a screen to crack from the inside. The two most common are pressure on the screen or dropping the machine. Sorry, but it is irreparable. You need to buy a replacement.
Hi kevinmmer,
I see you mentioned that the screen looks cracked but it isn't.
LCD screen can be damaged from within the LCD itself and may seem it is cracked but on the outside it is not only in the inside.
this is going to be unrepairable and will need replacing on your case.
I suggest that calling your computer manufacturer for any details about your machine if still in warranty or not of it is then that is good but you still may need to ask if the the LCD issue is covered on this case some manufacturers do not cover cracked LCD screen inside or Out.
I hope this helps.
Have a nice day,
mvincent
In a lcd or crt monitor there are 2 pieces. The piece that you are seeing that is not cracked is a glass like protector. Underneath is where the picture comes from and that is the piece that is damaged. In my opinion it would be cheaper to replace the monitor rather then get it fixed.
Hope this helps.
Bruce
