Could be a restricted inlet pipe just as you suspected.
http://waterheatertimer.org/pdf/ErrorcodeTroubleshooting.pdf
error 15 is 'Boiling safety device'
"Check for closed water heater inlet valve or restrictions in cold water inlet pipe (must be fully open).
Check for clogged heat exchanger (scale buildup).
On commercial water heater, lower setpoint temperature below 180F at high altitude."
Open following links for Rheem tankless resources including Rheem chat and phone support:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://www.rheem.com/products/tankless_water_heaters/customer_support/
Testimonial: "Thank you very much! We pulled the inlet screen out and we are backflushing the heat exchanger with electric pump and vinegar. Flow seems excellent."
Be aware of this --- http://www.cpsc.gov/cpscpub/prerel/prhtml07/07108.html And this --- Rheem RTG-95XP replaces RTG-74XP This makes getting information hard to come by. Please use the link below for information. http://www.rheemtanklessonline.com/contact.php
