You not need replace new filter all you can do get the NEC
VT460 remote control enter main menu
then go to default look at on right you will see All Data then go to Clean All Data hit ok, Your problem
should be shorted out Have nice day or night all.
How do pop out the filter to clean it?
My VT440 says this when it gets to it's pre-defined service life. (a certain amount of hours)
As long as you pop the filters out regularly and clean them (I use a vacuum cleaner) you shouldn't need to replace them.
After that, go into the projector options (with the remote control) and reset the factory defaults... otherwise it has no idea that you have actually changed the darn thing and keeps complaining no matter what! =-]
You not need replace new filter all you can do get the NEC VT460 remote control enter main menu then go to default look at on right you will see All Data then go to Clean Filter Usage hit ok, Your problem should be shorted out Have nice day or night all.
