NorStar Meridian M5009 Phone (NT4X35) Logo
Posted on Jun 14, 2011
Need to reset voicemail on a meridian NT4X35 9-button phone, do not have a manual.
  • Anonymous Nov 18, 2011
    How do I do this?
4 Related Answers
A
Anonymous
  • Posted on May 08, 2008
SOURCE: Voicemail
If the feature codes show as inactive, the phone system is not seeing the voicemail. Hopefully this has been fixed by now, but you may need to call in a Vendor.
Anonymous
  • 10 Answers
  • Posted on Nov 04, 2008
SOURCE: voicemail
Log into the voice mail server and you can reset the Voice mail for each account like it was a new account or you can delete the pass word on the account and then setup form the hand set. You do need to know the password to get into the voicemail server program. I believe as default it is NEC.
Anonymous
  • 192 Answers
  • Posted on Mar 20, 2009
SOURCE: Every button including feature Meridian 7310 calls to an internal
Sounds like a stuck button.
Do what I call the rake... swipe at the keypad over and over, look to see if there is any button lower or depressed on the keypad or buttons.
Someone may have spilled something on it (cola, coffee), and the set may require to be taken apart if there is a stuck button.
Anonymous
  • 10515 Answers
  • Posted on Aug 12, 2011
SOURCE: I have an m7208 Meridian Norstar phone. I have
Sounds like the FNA (forward no answer) on the phone is not setup.
Press feature **266344, then the installer password. Under Terminals and Sets, CFNA is under Capabilities.
Press Ftr985, and in the display you will see the Vmail DN. Enter Norstar programming and make sure the problem DN is CFNA to Vmail DN.
Let me know,once done so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Norstar m7310 phone, transfer to voicemail of different line
F983 then enter the ext # manually (not a speed dial/button), you must have 2 Intercom keys programmed on your phone.
Message button not working, can't access voicemail
You need to call your office manager, they will call in a tech to program the feature in the phone system for your ext.
Meantime try calling X7000 , most sites use that DN.
I have a Meridian M5316 and the there is an existing voicemail on the phone how do I change the voicemail without knowing the current password?
Your provider will have to reset it for you. Phone them and ask for a reset. They may charge you a dollar or so. But that is the only way
Feature Button
Sounds like the voicemail either is disconnected from the phone system or has lost power to the voicemail.Open the cover to the voicemail and see if there are any lights on in the system.If so then disconnect the power tho the voicemail for about 30 seconds. the voicemail could take up to 10 minutes to fully reboot.
Our voicemail transfer button will not work for oneparticular phone.
More than likely although the button is marked as a transfer its not programmed as a transfer button. To see how its programmed press feature *0 (button inquiry) and press the button marked transfer. To re-program the button press feature *3, press the button marked transfer,and press feature 70. that willchange the program on that button.
How do you change passwords without knowing previous passwords in order to change voicemail greeting??
Actually, even as a technician, you will never know the origonal password.
But you can get in to reset the existing password back to 0 0 0 0.
There are a couple of steps; depending on your voicemail system, voicemail's are done differently, but try this first.
got to a M7310 set
-> dial FEATURE 9 8 3
-> password: 1 0 2 0 0 0 0
-> you should now see ADMIN and under that MBOX, AA, OTHR
press MBOX
-> press CHNG
-> dial the extension of the phones that you need changed
-> you should now see PASSWORD and under it RESET, press RESET (This resets the mailbox back to 4- zero's)
-> hit the * to back up and repeat fopr all the other extensions.
-> hit RLS after all is done and voila... you have now changed those passwords to those mailboxes.
Now when the new users dial F981 at their desks, and dial 0 0 0 0 the first prompt they get is pleasde change password.
1helpful
When i hit the "vmail" button it beeps and says incoming only
That button is not programmed for voicemail, sounds like someone was playing and gave you a Target Line...
Press FEATURE * 0...
then the button that is giving you issues...
If the button says ex: 145 Line 145 that is a target line...
If you see Feature 981 that means voicemail.
My guess is someone gave you a Direct Inward Dial [DID] (a direct number) to your set.
Any button pressed on admin phone calls another phone's v.m.
Sounds like one of the speed dial buttons is stuck down on that phone
Voicemail
Top NorStar Lands Phones Experts
Paul Bade
Daniel Blask
Daniel Blask
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
