Question about Saeco Royal Professional Espresso Machine
No coffee, water going to the drip tray
I've had my Saeco Royal for almost 10 years and it has been working out fine. All of a sudden, there is no coffee coming out. The grounds end up in the container (dry) and the hot water goes to the drip tray. The machine seems to go through the whole cycle and there are no unusual sounds. There is no water or coffee coming out of the dispensing unit.
Any ideas? The central unit seems to be working fine.
  • cococoffee Sep 02, 2008
    No this did not resolve the issue.
    I put my brew unit into another Saeco and it worked normally. What I noticed was that the red rubber ring on the water spout that feeds the hot water to the brewing unit seems to be missing. Does anyone know where I can buy this spare part or what size the rubber ring is? Any help would be appreciated.
    Problem Solver:
  • 11 Answers
OK, so this is a problem with your brew unit. The unit is not cycling correctly to tell the water to come through.
We had another problem like this just this week.
The wat we fixed it was 1) Give the Brew Unit a really good clean. 2)Make sure the Brew Unit can complete a cycle - manually rotate the brew unit components through a cycle 3) Lubricate the Brew Units moving parts if necessary using some Saeco or Other Food Grade Lubricant
Then try watch a complete coffee cycle by leaving the side door of your machine open, and tricking the micro switches into thinking the door is closed by engaging them with some card or something similar.
Let us know if this does not resolve your issue.
Paul from Coffee Shrine
Saeco Coffee Machines
Posted on Aug 20, 2008
SOURCE:
I have de scaled my coffee machine. How do I override the decalcify signal
Hi I just looked at the manual online and its one of those menus you have to press one button and then more so a bit complicated to explain here but here is a link to the manual I hope it will help you.
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=en&scy=pe&ctn=0354.0RC.71N
Dec 16, 2014 | Saeco Royal Cappuccino Espresso Machine
New Royal Professional Machine has the workd Dregraw.miss can not use the machine what must I do to get started need help.
Hi
Dredge drawer is the big box on the bottom right. That is where the grounds are dumped. Remove the drip tray and pull the drawer out about half way. Push it back in with 1 finger on the right side of the drawer. That should clear the message. If it comes back on when you put in the drip tray, there is a section of the drip tray that can be removed to stop that. On the right side of the drip tray is a notch. Inside that notch is a thin piece of plastic. It curls up on the right side. Cut out the piece that curls up (just the piece that curls, about an inch). When you push in the drip tray that curl lifts the dredge drawer and knocks it out of position.
Jan 10, 2011 | Saeco Royal Digital Plus Coffee...
How to remove drip tray
Hi
Lift up on the front of the drip tray and pull out the front. There are 2 locking pins on the bottom of the drip tray that lock into the machine, that is why you lift up on the front of the drip tray before you pull out.
Apr 20, 2010 | Saeco Royal Cappuccino Espresso Machine
I purchased a second hand Saeco Royal Professional coffee machine and the frother does not work. When I press the button all I hear is a pumping sound but no suction what so ever. Also when I use the...
try inserting the frother in hot water its probably block and for our water everytime you whant steam open vale boiler start to boil water let the water drip into the tray wait untill steam come out pierre
Jan 10, 2009 | Saeco Odea Giro Plus Coffee Maker
Saeco Magic De Luxe Machine coffee grinds drawer overfills with water
Hi The thumb screw on the brew unit is stripped. If you remove the brew unit and you have water where the thumb screw is its stripped. you just need to remove the old one and replace it.
Oct 13, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco royal
Try to set the grinder to grind coarser, make 2-3 cup of coffee to get coffee with the new settings.
/Mirran
Aug 25, 2008 | Saeco Royal Digital Plus Coffee...
Hi, we have aa Saecco Cafe Grande an automatic Espresso Coffee machine. We purchased over 1 year ago from Future Shop. The machine only recentlly started to leak from the bottom, I did some...
Possible areas are the steam valve leaking or the boiler valve housing is leaking. I suggest Contact Saeco USA Inc. to located a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Apr 05, 2008 | Saeco Vienna SuperAutomatica Coffee...
Drip Tray and Container for coffee stuck
the only thing would our drip tray is not properlt install and is jamming the rest try to move in and out the drip tray i am sure you already try it but it about the only thing that can hold the rest take our time dont force it good luck cheers
Jan 20, 2008 | Saeco Royal Exclusive 30153 Espresso...
Water Leaking and not coming out from the nozzel
Thank you thank you!!! This problem has been irking us for months! The people in our company adore the coffee the Saeco Incanto Sirius makes so we just lived with the leak. The fix was such a simple thing, heh.
I used a cable tie to clean out the hole. The hole is very small - a design mistake, I'd say - and when I unclogged it I could see the cable tie coming out and coffee sludge flowing into the drip tray.
Dec 17, 2007 | Saeco 00034 Incanto Sirius Super Automatic...
Saeco Royal Professional Espresso Machine Logo
381 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ray Murphy
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
