Cars & Trucks Logo
Posted on Jun 14, 2011
I have a 2006 GMC Canyon and we were on a 4 hour trip, and about half way back home, we noticed that there was a strong odor. When we got home we found that the odor is coming from the battery box. Think that the battery has overheated somehow. Think it may be the charging system... any suggestions??
A
Anonymous
Test the Alternator & If the battery is from
06 & overcharged,etc replace it.
I don't know what you want here
I guess you already knew what I suggested
How can I remove my starter off a 2006 gmc canyon
2006 gmc canyon
For better result of your problem contact the reliable-store they have the best service manuals :))
How to remove the front rotor 2004 canyon
Park the Canyon on a flat stretch of road or driveway and open the hood.
  • 2 Remove the master cylinder cap located near the firewall on the right side of the GMC's engine. Remove half of the brake fluid in the reservoir with a turkey baster. Lay the cap over the container.
  • Read more: How to Change Rotors on a 2005 GMC Canyon ' eHow.com http://www.ehow.com/how_6717490_change-rotors-gmc-canyan.html#ixzz29JfCwiDq
    1helpful
    3answers
    Where is crank sensor located
    Lower front of engine derictly behind hormonic balancer IE the lower pulley on engine but before the oil pan two wires fairly easy to replace
    2helpful
    How do i get the spare tire out of a 2006 gmc canyon
    i pretty sure you go through the back right above the bumper and below the tail gate there should be a hole, and your truck should come with the tools u need ( probably with your jack) anyways you put the rod in there and unwind it.
    1helpful
    How to fix the Tailgate Handle on a 2006 gmc canyon truck
    Hello. This is not difficult. Order the part or buy it at a GMC dealership. It will come with instructions.
    2helpful
    3answers
    My canyon,s heater motor only works on high, is there a relay switch that has gone bad?
    the blower motor resistor is bad it is under dash on passenger side
    3helpful
    2answers
    GMC Canyon, computer shot.. cost?
    You can to the Salvage Yard for a new computer, but your going to have to get it reprogram to your ignition keys, so the Passlock will start the engine. Before you go through all of that. recheck every thing, it could be your crank sensor or your ICM faulty causing your engine to shut down. Keep me posted and let me know what DTC codes you have. Note: a faulty fuel pump or dirty fuel filter will not set a DTC code. You may have a dirty fuel filter or faulty fuel pump or faulty fuel pump wire harness or fuel pump relay.
    Cruise coontrol inoperative
    check your fuses. If it quit working immediately after the recall work then you need to take it back and make them fix it.
    Top GMC Experts
    ZJ Limited
    ZJ Limited
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    john h
    Are you a GMC Expert? Answer questions, earn points and help others
