It could be "sort of" either. If the power supply fan is labouring or stopped, it will overheat very quickly and force a shutdown or blow a fuse. Because of the latter usually this will only happen a few times, and then perminently. If the cpu fan bushings are clogged with jam, and it is labouring, the cpu temps will shoot up and trigger a bios level shutdown. So you need to do some checking, and perhaps some cleaning. Usually if there are motherboard problems, you will get beeping indications of device checks. If there is no picture, then the vga card could be loose...but again, beeping for sure. loose power cord connect or worn - problems, not always a beep here. Check a cables and connections but the first checks are likely the root.
