SOURCE: toro self propelled mower will not move
This is a very simple solution, When you pull the lever it simply pushes a pulley into the belt to make it tight. Most of the time the belt has come off or maybe the cable broke. Turn the mower over and you will see the belt. My money is on the belt off.
SOURCE: SELF PROPELL NOT WORKING GOOD
Have you checked the belt that drives the wheel? This is more than likely the problem. It may be broken.
Jim
SOURCE: toro self propelled 22 inch recycler lawn mower start pull cord is "stuck"
Casey,
My son just bought a new Toro self propelled 22" recycler and has had problems on two different occasions. The mower just bogs down to a stop and when he tried to pull the starter cord, it was very VERY difficult to pull. At first I thought the engine had seized up for some reason (no oil?), but we found the problem.
First, disconnect the spark plug wire from the spark plug (to avoid the engine starting); tip the mower on its side and check very carefully the pulley and transmission belt. In his case, a piece of wood had gotten stuck between the belt and the pulley. Removing it fixed the problem (now he mows a little higher so as not to get so close to any debris). (We did have one further problem after that - the engine would not start - not even fire. After pulling and pulling, checking for gas, and checking that the air filter was cleean, we decided to check if the cylinder was flooded - we removed the spark plug, wiped and dried if off, and replaced it. It started right away.)
This belt 'n pulley arrangement isn't the best idea, if you ask me.
Good luck.
SOURCE: 6.5 toro walk behind self propell b&s engine.
Try adjusting your self propel cable. A slight extension of the cable (1/4 inch) will double speed, so do a little at a time. Take the back guard off and clean debris 2 or 3 screws and it is just a cover so nothing will pop out unless that is your real problem. You should have grease fittings behind rear wheels so squirt 2 times with grease gun in each wheel and 1 squirt every 3rd mow.
SOURCE: my toro 20016 self propel is only turning the right wheel
Remove the left wheel and check the gears inside the wheel and the drive sheft. They might be worn or sheared and need renewing or maybe they just need oiling. Spray them with WD 40.
