Hello i am for mexico sorry for my english but i have a problem with a vsmile pocket when i put a game catridge this don't turn on if a remove catridge vsmile pocket turn on whitout problems i need your help
Hello sorry for my English Look it's very simple and easy to fix ok Just take off ur radio and then u well see 2 cable 1 Reed color and the other one its yellow. take off the red one and put it en instead the yellow and the yellow instead the red and the problem its resolve Sorry again for my English
I don't understand. Put this in engles (english) por favor (please). If this isn't in spanish, then sorry. I'll need more details if this is in english.
Hello, does the dryer drum turn? If the dryer drum is moving. Is the dryer blowing hot air, cold air, no air at all? Now, if it's doing everything mention above escept blowing hot air then you'll need a new heating element. If not blow air, then the drum belt is broken, belt off, or the drum motor has gone south. It was put for a quitt. Which mean in New Mexico, they fired me, I don't work, no job, finished, I'am out of here, don't bury me with my wires exposed. I hope I was some help to you. have a nice day and be safe, GB. stewbison
take batteries out of console. Hold start button on console for 45 seconds. put batteries back in. press start to turn console on. controllers should work now
you have to do this in the right order or it doesn't work. Start with the TV and Vsmile OFF
step 1) put the cartridge in and make sure it is all the way in
step 2) turn the TV on
step 3) turn the Vsmile on
if it still doesn't work, unplug the adapter or take the batteries out and let the system clear and then do the steps over. Good luck!
We had the same problem. Put alcohol on a q-tip. Pull back the plastic sleeve on the Smartridge (game) and clean both sides of the metal contact. Insert the Smartridge into the Smartridge slot and remove quickly. Then insert Smatrige and turn on the power.
I did this to all of the games and now it works like new!
Hi I'm ryan, try resetting it. Remove the battery cover, there should be a pin hole with a reset button in it. my daughters did the same thing and i just reset the system and it works fine.
All you need are 4 AA battery of anykind. Open the back cover, remove the Vtech rechargable battery pack and insert 4 AA batteries in its place. Now your child will enjoy there Vsmile again.
Do you still have your receipt? You could try to echange it at the store. Vsmile is coming out with a newer slightly different handheld model you could try. Though, we have a vsmile for the home and a leapster as a handheld game. Which both of my children have loved. Have you tried calling Vtech about the problem? I've had to call before about the home unit and they were very helpful. (Incedently, I have had problems with that, so if you ever do here's a helpful tip: Reset the machine by unplugging EVERY cord and pressing the two front buttons together for one full timed minute! We were having problems with a power issue and this solved it) They may be just as helpful as Leapster's Leap Frog company and send you a replacement! Once on a long car trip my daughter got sick in the car, while playing, so needless to say the game system got it too. And when I called Vtech about what to do, they sent a replacement! Try calling Vtech and see. You never know! Good luck!! :)
