Car Audio & Video Logo
Posted on Jun 13, 2011
Necesito los cables que salen del equipo addzest vrx835 todos los que salen desde la maquina
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 13, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
119
Points
I need the cables for equip addzest vrx835 please awnser me please!!1:)
Trying to set up my Insignia TV model # ns-40e560a11 to my Onkyo AV Receiver model # TX-SR307 I could use a wiring diagram or some kind of help to get my Home theatre system setup thank you.
Hello Scott, to be able to guide you, in wiring so that you can have everything in your home theater system, you should comment that equpos you have
I can suggest a generic connection to have the sound of each source in Tu Onkyo
You have to connect the equipment that has HDMI output, in the corresponding entries in your Onkyo, accounts with only three inputs, if you have more than three equipment with HDMI, you can connect it to an HDMI input on the TV
If you have other equipment that does not have an HDMI output, you should connect it to the remaining inputs of the Onkyo, according to its type
Then, you connect an HDMI-HDMI cable from the HDMI output of the Onkyo, to the HDMI 1 input, of the TuTV Insignia
And you also have to have a Fiber Optic cable, connected from the digital audio output of the TV (it is located on the side panel of connections) to the Fiber Optic input (Digital In) n ° 1 of the Onkyo, this connection allows you to listen to the sound on the Onkyo of everything you are looking for on the Internet, eg Netflix, YouTube, etc.
In this way you would already have everything connected in the Onkio and you could enjoy the sound of the Home Cinema System
I hope you manage to interconnect everything and you can enjoy a good sound and an excellent image
I send you the links of the user manuals of TV Insignia and Onkyo, in case you need more information
Greetings Franco Dosil
Hola Scott, para poder guiarte, en cableado para que puedas tener todo en tu sistema de cine en casa, deberias comentar que equipos tienes
te puedo sugerir una conexi?n gen?rica para tener el sonido de cada fuente en Tu Onkyo
Tienes que conectar los equipos que tengan salida HDMI, en las entradas correspondientes en tu Onkyo, cuentas solamente con tres entradas, si tienes mas de tres equipos con HDMI, puedes conectarlo a una entrada de HDMI en el televisor
Si tienes otros equipos que no tengan salida HDMI, los deber?s conectar en las entradas restantes del Onkyo, de a cuerdo a su tipo
Luego, conectas un cable HDMI-HDMI desde la salida HDMI del Onkyo, hasta la entrada HDMI 1, del tu TV Insignia
Y tambi?n tienes que tener un cable de Fibra ?ptica, conectado desde la salida de audio digital del televisor (se encuentra en el panel lateral de conexiones) hasta la entrada de Fibra ?ptica (Digital In) n°1 del Onkyo, esta conexi?n te permite escuchar el sonido en el Onkyo de todo lo que buscas en Internet, ejemplo Netflix, YouTube, etc
De esta manera ya tendr?as conectado todo en el Onkyo y podr?s disfrutar del sonido del Sistema de Cine en Casa
espero que logres interconectar todo y puedas disfrutar de un buen sonido y una excelente imagen
Te env?o los link de los manuales de usuario del TV Insignia y del Onkyo, por si necesitas mas informacion
Saludos Franco Dosil
https://www.eu.onkyo.com/downloads/1/1/9/7/8/21637364_3342ba722d.pdf
https://data2.manualslib.com/pdf4/98/9771/977072-insignia/ns40e560a11.pdf?5272bbc74f2dc78e6eb01f3f6deb2aec&take=binary
Castle autoclave 3533
Tiene usted los manuales de funcionamiento, instalaci?n etc. Yo tengo el mismo equipo
Recientemente conecte la Pc a internet y al realizar las actualizaciones, en el reinicio en el momento de configurar las este win no arranca se apaga y prende en un ciclo que no acaba. no dispongo de disco...
Usted puede tratar de arrancar en modo seguro pulsando F8 durante el boods m?quina. Una vez en modo seguro se puede tratar de hacer una restauraci?n del sistema de la, en Inicio, Todos los programas, accessores Herramientas del sistema • Restaurar sistema. Si esto no funciona, entonces usted tiene que hacer una restauraci?n completa del sistema o la recuperaci?n del sistema en funci?n de su computadora. La mayor?a de los nuevos equipos le permitir? hacer una recuperaci?n del sistema pulsando una de las claves durante el arranque. Usted va a perder todos los programas y todo lo que est? en el equipo. Usted puede ser capaz de hacer esto sin tener que formatear el disco duro.
I’m happy to help further over the phone at https://www.6ya.com/expert/al_e83b1941f9c0f302
17helpful
6answers
Como puedo arreglar el audio de mi compuntadora
mi pc es ACER ASPIRE T160, no puedo escuchar el sonido, el problema es desde el comienzo no da sonido ni al prender
Pc lenta
Los problemas en tus maquinas son de virus y conflictos de software. En el caso de la # 1 es posible que este lenta por problemas de hardware, pero si decis que en las otras hay troyanos es muy posible que toda la red este infectada. Los troyanos la unica manera de erradicarlos definitivamente es formateando las maquinas y reinstalando todo de nuevo. (Los antivirus por mas efectivos que sean no sacan este tipo de problemas y a la larga terminas reinstalando todo de nuevo) Te recomiendo hacer un respaldo de todos tus archivos, y reinstalar todo desde cero.
1helpful
2answers
Idioma
Si lo has comprado en un pais donde se habla espanol, o en un pais europeo o en los EEUU deveria de tener el espanol en los seteos del idioma. Si es asi aconsejo de ir al vendedor y chequear.
Si no tiene espanol puede ser de improtacion. En este caso tienes que re instalar el firmware.
No se si le valdra hacer el update desde el telefono (nececita conesion al internet). Yo aconsejo de ir a un vendedor de telefonos y pedir de reinstalar el software del telefono, es una operacion bastante sensilla. aconsejo de grabar todos los contactos anter de llevar el mobil a la tenda.
Otra solucion podria ser bajar el software desde el internet i instalarlo usted con un cable y una ordenadora, esta operacion tiene un poquito de riesgo si nunca lo hizo antes.
Top Toyota Car Audio & Video Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Toyota Car Audio and Video Expert? Answer questions, earn points and help others
