Question about Refrigerators
How to get glass out of shelves for cleaning - Refrigerators
    Brigadier General:
  • 3,301 Answers
Most shelves have the glass attached to the side brackets,, empty the shelf, and at the back of the fridge,, you'll see slotted rails that go top to bottom,, tap the shelf bracket upwards and it should come right out,, be careful,, once off the glass may come out too,,
Posted on Jun 13, 2011
SOURCE:
I have a U-line model 75WC. Want to change out wine racks with glass or wire shelves to change it to a beverage fridge. Any ideas on parts? Can I buy shelves for another unit to make this change?
glass shelves you can get cut from a glass suppler or window shop
if you have the measurements you may get wire shelving from a fridge service agent spares or cut wire fencing to size and have the parts powder coated to prevent rust
even aluminum security doors cut to size may do the trick
Aug 09, 2018 | Furniture
RF197ACRS Samsung fridge How to remove glass from the shelves to clean
Well, I don't know about the individual shelves, but for the long glass shelf above the crisper drawers, there are two white clips located at the back edges of the glass that need to be pried out with a knife blade, or something similar. Place your blade in between one of the grooves of where the clip meets the plastic frame (and, NOT between the clip and glass! ) and pry the clip with a bit of a sideways motion. It's a little stubborn, but if you break a clip, don't worry, you really don't need it for the shelf to function.
Anyway, after you pry up the two corner clips, lift and slide the glass toward the back to get it out of the front groove, and voila!, the glass comes right out.
Aug 14, 2015 | Samsung / RF197ACRS
How to remove the glass shelf for better cleaning PSC25MSSC
if the glass has plastict trim like pieces across the front and rear edges try pushing up on the glass close to the plastic trimat th rear end, the trim should swivel up and the glass pop out of the groove
May 03, 2015 | GE Refrigerators
Where can I find a glass shelf 79cm width?
Call a glass shop and they should be able to steer you in thhe wright direction
May 04, 2014 | Furniture
Howto Clean the glass shelves in my LG refrigerator
Will they go in the dishwasher? If not, use an old toothbrush to get into the edges; use lemon juice or vinegar to degrease, rather than a bleach.
Apr 24, 2014 | LG Refrigerators
Turned it off,Took out glass shelves to clean, now shelves won't slide back in!!
sounds like liner has expanded because it warmed up try turning it back on let it run overnight and try again
Nov 03, 2012 | U-Line 1175BEV Beverage Cooler
How do I remove shelves for cleaning an lg French door refrigerator?
On my Kenmore (795.7555* made by LG) French door, the adjustable shelves are removed by tilting them up and then bringing them forward. The sliding shelves and drawers just pull forward.
Which model LG refrigerator do you have? There may have been design changes between your fridge and mine. Please add a comment with the information for specific instructions.
I hope this helps.
(I didn't bother to give the full model number of my fridge since the directions also apply to the 795.7519* and 795.7554*)
Jul 06, 2012 | LG Refrigerators
Glass shelves stuck together when shipped. can't separate new glass shelves for installation in medicine cabinet. there wasn't any paper between the glass shelving when it was shipped. it is impossible to...
You could try soaking them in hot water and see if the warming of the glass will allow some water to seep between the shelves, thus separating them.
Please rate this answer for me. Thank you
Mar 22, 2010 | Home
Cleaning Glass shelves mold.
the shelves can be removed not taken apart. sorry they're glued together, just use a bristle brush and some bleach. no problem.
Mar 30, 2008 | Refrigerators
Refrigerators Logo
273 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
