Here is theinstruction:1. Install the battery2.Use left attor to decrease and right arrow to increase numbers < > to set current time to nearest hour at the time, noting AM and PM3. Repeat above instructions to set "start time: to desired time for day to begin watering4. Use left and right arro <> buttons to set "how often" (watering frequency) to select an hour/day increment (8 hours=3 times per day, 2 days=every other day).5. Use left and right buttons < > to set "how long" (watering duration) to select a min. or hr increment.6Activate the watering program by pressing the Program on/off buttin: a horizontal bar will be displayed to signify the program is on. Press the program on/off again to disable the programTo avoid accidentally changing the current program, the arrow button will be "locked out" or inaccessible if "program on" is selected.To create a new program, press Program on/off if necessary to disable current program.
What I would like to know,is how you set your timer to water twice a day instead of three times a day. How to set the timer to water once in the morning and once in the eevening.
lnodley - you asked this question 3 years ago. I guess that is long enough to wait. Set the time to 12 hours instead of 8, and it will water every 12 hours (2x per day) instead of every 8 hours (3x per day). There you go!
