Question about Powerware 9120 UPS System
I have a powerware 9120 (6kva) and about 1 week i replaced all 20 batteries after the UPS failed. but its displaying battery disconnected when i try to power it. i cant seem to figure the problem. i tried rplacing the charger board but it didnt work. i also tried replacing the main board but it also didnt work. please help me find a solution
    Scholar:
  • 39 Answers
Did your UPS display "Battery disconnected" or did it display "Battery Failure"? If it was "Battery Failure", for some reason the Powerware 9120 will take almost 18 hours after plugging in to power after battery replacement to correct the Battery Failure indication. Charger has to charge up the batteries, followed by an automatic battery test by the UPS. If the indication was "Battery Disconnected", you will need to check the internal fuses to see if they are blown. If the UPS keeps blowing fuses, it will require a board repair.
Posted on Jul 13, 2011
2 Suggested Answers
SOURCE:
  • 25 Answers
SOURCE: control board for powerware 9120 6kva ups
did you get what you needed?
Posted on Jul 11, 2009
I have a powerware 9120 6000kva . I replaced all 20 batteries, but after 20 hours its displaying charge failure. What can I do?
You can check the battery fuse or the charging fuse. If it's more then that it's going to be a very costly fix.
Jul 24, 2015 | Powerware Computers & Internet
What battery is used in the powerware plus 36
I would takes 20 batteries to make one string:
1. GPS- 58EGPS-12-26-I
or
2. Yuasa - NPX-150R
or
3. Data Safe 12HX150-FR
Feb 12, 2015 | Powerware Plus 36 UPS System
BAT DISCONNECTED ERROR DEPLAY
It's probably a failed battery going open circuit or DC voltage is below limit on a cell
Nov 26, 2013 | Powerware 9120 UPS System
We had a power outage for about 45 minutes a few days ago. Ever since then the Powerware 3110 has been beeping. I turned it off and left it plugged in overnight and when I turned it back on the beeping...
This could be several things, fortunately the device should actually be helping you to diagnose the issue. There are different beeps for different issues. They are as follows:
1 Beep Every 5 Seconds = Power Outage\Loose Plug Connection\Tripped Circuit Breaker\Power Cord Damage or Failure
2 Beeps Every 5 Seconds = Low Battery Alarm
3 Beeps Every 5 Seconds = Battery Needs Charging\Service\Replacement
3 Beeps Every 5 Minutes = The Battery is discharged and battery power is unavailable (If this continues battery replacement may be necessary)
1 Beep Ever 1/2 Second = Power Requirements exceed the UPS Capacity (remove some equipment to lighten the load on the unit)
Continuous Beep = Short Circuit / Input Voltage out of Range / UPS Fault (Likely replacement of entire unit)
That should help diagnose the actual issue. If it turns out the battery needs to be replaced they can be found online for around $20. A simple google search for Powerware 3110 Battery should return what you're after. Good luck!
May 05, 2011 | Powerware 3110 UPS System
Need to locate someone to install batteries into our UPS Powerware 2000. Location, Tempe, AZ (Phoenix, AZ)
Try contacting Eaton. They bought Powerware about 6 years ago and the personnel are trained on older Powerware systems. If you have the part number and serial number from the rating label on the UPS, that would be helpful.
Toll Free: 1 800 356 5737
E-mail: SinglePhaseTS@eaton.com
Nov 24, 2010 | Exide /Powerware PowerWare 2000 UPS...
When the machine is power on it show disconnect battery powerware 9120 2kva
There may be a broken batt lead or a failed cell or bloc inside.
try checking with software or
take out batts and test with meter.
if you dont understand how then get a tech to help. batts are dangerous.
Sep 13, 2009 | Powerware 9120 UPS System
My ups has is faulty i need a circuit diagram to fix it
I had a DC bus fault error displayed.
So I unplugged battery, then turned on UPS. It said Batt disconnected of course.
So when I plugged in the batt while the UPS was on, and held the power button for a few sec, the UPS displayed Batt testing.
After a few moments it was back online and had no faults!
Worth a shot.
May 20, 2009 | Powerware 9120 UPS System
The UPS dont go to on batteri
Replace the batteries with new one then power the UPS without load for three hours or more so that the batteries can be charged. Then disconnect or switch off power to the UPS and observe if it will till be on using the batteries. If it will be ON then your problem is solved but if it goes off then your UPS is on BYPASS
Apr 09, 2009 | Powerware 9120 UPS System
9120Powerware batteries
check the fuses inside the ups.
did the message come right after u instal de batteries or some time after?
if it came some time after the ups could have the charger damaged.
if gave the massage right after u could need to replace the fuse or u have a porwerboard problem
good luck
Jun 20, 2008 | Powerware PowerRite Plus UPS System
Powerware 9120 UPS System Logo
1,200 people viewed this question
Top Powerware Computers & Internet Experts
Marvin
Marvin
geekyshrink
geekyshrink
Level 1 Expert
B.Th. Pluijm
B.Th. Pluijm
Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
