It can, however, you should be able to login to the modem and increase the strength of the signal being produced. You can go to Start>Run and type in: CMD
This will bring up command prompt. Type in: ipconfig
Find the default gateway code and then load internet explorer and type that IP Address into the address bar. You will need the login to that router though to be able to change the settings.
Hope this helps! Please rate my answer :) Thanks!
Yes. definitely it will help. make sure you disable the modem's wifi and/or choose a different channel
How do you use a different channel? I don't want to disconnect the wifi cause it helps my iphone signal.
