The problem is the spring on the Sneak a cup feature is too strong and pushes the basket up thus shutting the valve off and causing overflow.Just pop that thing right off! Problem solved! Works like a charm 100% of the time no matter what type/grade of filters and even if you get 2 stuck together......."Sneak a Cup"? Some things in life are worth the wait!
You might have a bad batch of filters that are not letting water through. Water eventually overflows and brings grounds with it. Good luck.
