Hi er_gauravpra,
I see you want to use an HDMI connection for your Video from your Lenovo Y510.
I have checked information about the Y510 and it does not have the Technology of HDMI on the Y510 system of Lenovo, Y510 system only have the VGA port where in you can use a VGA cable to get video output to an External Monitor.
Regarding the issue about HDMI I have not seen any Converters yet that can be bought from anywhere to convert VGA to HDMI and I believe that will not be possible since VGA is a lower type of video output than what an HDMI can.
I do apologize but the Y510 systems does not have the HDMI technology to on it.
I hope this clarifies everything about your Query.
Have a nice day
mvincentc
Your Lenovo laptop can be hooked up your TV if you have a model that is
capable of TV output. Newer models with HDMI ports can easily connect to newer
TVs that have HDMI input jacks. For older laptops or TVs, you will need other
adapters or cables. The most common of these is an S-video jack, which has a
small round connector with several pins arranged in a circle. For S-video
connections, you will need to hook up the audio from your laptop to your TV
separately.
Things You'll Need
HDMI cable
USB-to-HDMI
adapter
OR
S-video cable
Audio cables
HDMI Connection
Turn on your
Lenovo laptop and HDMI-enabled TV.
Connect one end
of your HDMI cable to the HDMI port on your laptop. Lenovo's IdeaPad series has
these ports. If you have a ThinkPad or other Lenovo model, connect a
USB-to-HDMI adapter to your HDMI cable, then plug the USB end of the adapter
into any USB port.
Press the
"FN" and "F7" keys on your keyboard. This will switch the laptop's
display to the TV. You can then use your TV screen as a monitor or use the
laptop's DVD drive to watch movies on your TV.
S-Video Connection
Turn off your
laptop and TV. Connect your S-video cable to the laptop on one end and the TV
on the other.
Plug audio
cables into your audio out jacks on the laptop. If you do not have stereo audio
output, you can use the headphone/speaker jack. Add a splitter adapter to split
the sound into stereo instead of mono (single speaker). Plug the other ends of
the audio cables into your TV.
Turn on the
laptop and let it boot up. Then turn on the TV. Right-click on your desktop
screen, then select "Properties."
Click the
"Settings" tab, the "Advanced" button, then "ATI
displays" or "Display device" or the similarly worded option,
depending on your system. It is not the "On screen displays" option
in any version.
Click on the
option that suits your system, such as "TV" or "LCD." Click
"Apply," then "Yes" to confirm, if necessary. Click
"OK" to exit. Your display should be visible on the TV screen. If
not, try pressing "FN" and "F7" to toggle the display to
the external screen.
Hope this helps someone! If you have any other ideas or suggestions, please feel free to comment!!! Thanks!
