HP Spare Key can be
used to reset BIOS password. It is provided by HP Corporation. So when you
forgot BIOS password on HP computer, just download it and get perfect BIOS
password reset.
How to reset HP bios
password with Spare Key or other ways?
Please refer to reset
HP Elitebook password. In this
passage, you also can learn how to reset Windows administrator password
easily.
http://www.isunshare.com/windows-7-password/reset-hp-elitebook-password.html
Just a few days ago, I lost my windows vista admin passwords. I solved the trouble with the help of windows password reset tool. It not only support XP/Vista/2000/NT, but also compatible with windows 7, I tested it on my computer installed with Windows 7 and remove the local user and admin accounts password successfully. It's worth trying. You can download it from: http://www.reset-windows-password.com
Four days ago, I had an embarrassing experience that I forgot Windows administrator password. As there is so much important data on my desktop, I can not reinstall Windows. However, I thankfully found a useful tool Windows password Seeker at about.com PC support channel. I download the program from passwordseeker.com and followed step-by-step instructions. Finally, I removed Windows password successfully. http://www.passwordseeker.com
A BIOS password is a protection measure that can be used to stop someone powering up a computer system or making changes in some of the computers most sensitive areas. Many big name computer manufacturers such as Dell and HP lock the customers out of this area because they don't want the customer changing anything and potentially damaging the machine (which the manufacturer may have to warranty). However, when someone like a computer technician or hardware enthusiast needs to make some hardware changes to the computer, they will need to access the BIOS. Here are some methods to bypass or remove a BIOS password.
NOTE: Do not try to guess the password on a passworded Hard Drive. 3 wrong guesses will often result in the information on the hard drive being lost forever.
To clear the BIOS password, find the Cmos Battery in your Laptop and disconnect it from the motherboard for at least 10 minutes. This will clear the CMOS and clear the passwords. Connect the battery and power on Laptop..
i have tried it that way before, i even left the CMOS battery disconnected for over 2 weeks,but when i connected the battery back and try to access the BIOS, the password is still there. please help.
I recommend MIT Bios Reset & Recovery Service to get your master password to clear all bios passwords and unlock your HP laptop . They are cheap only $20 and they reply quickly with your master password.
Link :- http://www.mastermindit.biz/bios_reset_h...
thanks, i will try that.
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
thanks,i will try that.
