Radio Shack Pro-2018 Scanner Logo
Posted on Jun 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a realistic pro-2023 lost manual and can`t reprogram it ,have u any ideas.....................baz
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Mar 24, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
3888
Points
I also need same manual have contact no for someone who may be able tosupply
Anonymous
Level 3:
President:
  • Master 2,761 Answers
  • Posted on Jun 13, 2011
Anonymous
Master
Level 3:
President:
Answers
2761
Questions
Helped
933568
Points
7369
You can download and print the operating instructions for your scanner, at no cost, here:
http://support.radioshack.com/support_electronics/doc18/18513.htm
Bill B.
Listening in since the 60's
Realistic uhf/vhf model 20-400 pro 58 ten channel. Where can I get an owner's manual?
Products associated to Radio Scanners - RadioShack.com
support.radioshack.com/productinfo/ProductResults.asp?...Scanners...
Get Acrobat Reader. Previous Page. Products associated to Radio Scanners. SKU/Catalog #, Model, Description ... 20-139 · Realistic PRO-38 10-Channel Direct Entry Programmable Scanner ... 20-313, Pro-76, Pro-76 200-Channel VHF/AIR/UHFHandheld Scanner ... 20-400 · Realistic PRO-58 Programmable Scanner.
Looking for a manual for a Realistic Patrolman Pro 40 UHF/VHF Scanner. I don't even know what kind of power supply it needs.. LOL
Hi, that unit looks to be a mobile scanner and if I'm seeing right then you would need a Base power supply that could supply 12volt to it. Course you could also use a computer power supply and find the 12 volt line out on it. Here is the link to some spec's for it. Looks also to be crystal controlled so it cannot be reprogrammed. Good luck.
RadioPics Database RadioShack Realistic PRO 40
RadioShack Realistic Pro 40
1helpful
I need codes for my realistic pro 2023 scanner
Codes? Assuming that you're looking for frequencies, you can find a comprehensive database of active frequencies in your area, and a lot of other useful scanning information by visiting:
www.RadioReference.com
Bill B.
1helpful
Have a pro 2020 realistic programmable scanner. got working bu after turning off, turning back on will not scan. just shows - - - - - - - - . on screen
The memory on the unit is not retaining the frequencies. Check for a small battery on the circuit board like a button battery you would find on your computer motherboard. Replace the battery and reprogram the unit.
Neighbor gave me this Pro-508 as it had lost it's freqency programming. I reprogrammed only to find it "instantly" loses all programming if power is disconnected. Specs say it should hold for 1 hour. ...
You can to to RadioReference.com and join the RS forum. There you will find references and manuals for just about any scanner from Radio Shack, and places to get parts.
Lost owners manual need to reprogram the light
have you been to www.aerogarden.com. they have a troubleshooting area for the reprogramming of the lights.
2answers
I lost my code sheet and I can't program my scanner any suggestions? It's realistic Pro 2023 Scanner
Radio Shack has a pretty good search feature for old instructions on their website. You will need their part number off the unit, which will be something like "20-321". Do a search and you can get a PDF instruction manual for it online.
How can i program a realistic pro 2023?
Hi there - I will admit I am no expert with scanners but I did find these instructions that will hopefully tell you what you need:
http://support.radioshack.com/support_electronics/18517.htm
1helpful
I just cannot reprogram this unit following the instruction manual..Help!
once you delete them i bielieve there gone radio shack does carry a book of frequiences you can program in depends on what you want listen to
Top Radio Shack Radio Communications Experts
John
John
xxxxxx xxx
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
