How to configure Mitsubishi tv to setup Sony blu ray player
The set should in owner manual have detailed instructions with diagrams etc.
Basic is from player outputs (whichever it uses) HDMI, component etc OUT to the same on the set(usually into a rear input) IN, select that input on the TV and if player good you should have a working system.
When you want to go to use the player select that input (most Mitsubishi sets will allow you to change from input # and label that input DVD etc--that's in the TV setup menu most of the time.
The more things you have connected to the set the more complex it can get.
