First, you can only get digital channels now,so you must have a tv that can receive digital. You can buy digital tv antennas that can receive about 70 miles that mount outside or in your attic. This FCC site can show you where to point the antenna to get the best signal:" https://www.fcc.gov/media/engineering/dtvmaps
Also you can get a signal booster that will help if you can get a minimal signal. The booster will only amplify a signal so if you cant get one at all it won't help.
SOURCE: no remote or service manuel
You need a remote to access the menu. Call the phone number on the label on the back for assistance.
SOURCE: Digital TV flunked the digital test
The news reported that that several people, despite having cable, satellite, or digital ready televisions still saw the failure test...some sort of glitch. It caused a great deal of confusion. If your mom's TV is digital ready, she is probably one of the many who saw the failure signal by mistake. I thought you didn't need a converter box in with digital ready TVs, but maybe you do. Definately call the manufacturer and ask...I think there's a deadline on the coupons for converter boxes, so definately check this quickly. Good luck.
SOURCE: Toshiba 26AV502U Won't Pick Up Channels
Hi albertogiler,
I am happy to help, you will need to attach a antenna to the tv to pick up OTA over the air signals, depending on your location you may be able to use a set of rabbit ears, I have provided a link to a site that will explain in depth.
http://www.antennaweb.org/aw/welcome.aspx
Let me know if this helps and please rate this solution. lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
SOURCE: Auto Scan doesn't pick up any channels.
In the main settings, there should be an option for AIR or CATV, air is for non-cable and CATV is for cable tv. This has to be on the correct setting before you autoscan
SOURCE: My Sylvania 6626LCT TV has a problem with one of
Hi richgun,
Click this link http://dl.owneriq.net/e/e48faa76-28d7-4e6f-9988-891f8f0a17af.pdf. Perform page 18.
Hope It may help you.
Have a nice day!
Thanks for using Fixya.
3 Connect cable or antenna, then select OK to run Auto
Program
• If you have cable and antenna available, please connect cable first.
• IMPORTANT: Auto Program is only effective when cable or
antenna is connected. If you cancel Auto Program before completion some channels may not be
available.
4 Auto Program will scan for available channels from the signal source directly connected to
the TV's CABLE/ANTENNA input and may take sometime to complete the process. Follow
the help text provided on the screen to run Auto Program.
OK.
