For G Shock GW500Uthe screws holding the ******** are actually just one pin per strap the screw end is for decoration. To remove just get small headed flat screwdriver and push pin through it is fidely but can be done it took me 10 mins first time. Casio sell straps direct for about 10 pound cheaper than putting into casio dealer .
SOURCE: change casio g shock resin watch band
It can be done and not too difficult i think but look out that the leather band ain't too wide for the band orginal place,
make sure you keep all original parts in case of toruble
Post a photo if you can after the change will be nice to see the change
Tom
SOURCE: changing the band on my casio oceanus 500 wristwatch
If its an OC500, I just figured it out. There are two sides of the pin visible. One has a dimple and one is completely smooth. Use a small phillips or a punch that is the same diameter as the pin and push on the side with the dimple. The pin pushs in only about 1/4 inch and the smooth side protrudes from the other end. Pull or pry on the smooth end to extract it. The pin is actually 2 parts so be careful not to lose the dimple side piece.
