Your battery MOST LIKELY has lost some of the battery cells, which will cause it to get a partial charge which will show it as a FULL charge when in fact it isn't getting a full charge. You should try taking it to get the battery tested and they can tell you if it needs to be replaced. I would guess they are going to replace it for you. A new battery should run around $90 for a motorcycle. Let me know if this helps you out. Jeff from fixya
Testimonial: "thanks so much! very helpful"
