GPS Logo
Posted on Jun 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a wiring diagram for a jvc ks-sra 100 - JVC GPS
Robert LaFramboise
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 2 Answers
  • Posted on Aug 30, 2020
Robert LaFramboise
Contributor
Level 1:
Welcome Back:
Answers
Questions
0
Helped
264
Points
17
For all those in need - here's a schematic I drew up. It's got a fuse, and filtering (inductor / capacitor) - but the connector is a 4-pin MOLEX like you see for +12v on an old P4 board. Pin 2 - (GND) Pin 3 - +12v (out of this schematic box) - could try it with just a fuse no filter, but JVC link is VERY unreliable when there's noise
Got problems with your KS-BTA200 adapter anyone? Here's the problem - inside the adapter, they wanted to save 1 screw, so they grounded the shield to the holding bracket (which "touches" PCB ground sort of). Buy a 20c M4 sheet metal screw, 5c star washer you'll see a spot for shield ground on the PCB and housing inside the KS-BTA200. Ground that sucker right - my old one that went out works SOLID now :) (pass it on)
I need a wiring diagram - ks-sra100-(power_cord)-gvux3kiokajvd5y1ar3i0axc-6-3.jpg
Hopefully you can see the schematic, website is bogging down
Anonymous
Level 3:
  • Master 910 Answers
  • Posted on Jun 11, 2011
Anonymous
Master
Level 3:
Answers
910
Questions
Helped
306533
Points
2616
Free PDF Manual at the link below with Wiring & Cable Connections.
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/105/105KSRA100.PDF
In need of Jvc KD-S29 wiring diagram
The wiring guide for the KS-S29J is on page 2 of the installation guide. This is available on the JVC support page. Start at http://books.jvc.com/ and enter the model number. The direct link to the installation guide is http://books.jvc.com/Download/1069593248/GET0863-002A.pdf . The direct link to the owner's manual is http://books.jvc.com/Download/1069593248/GET0863-001A.pdf .
I hope this helps.
1helpful
Wiring diagram for jvc model no ks-fx460r
http://books.jvc.com/booklist.asp?Model=+ks-fx460r this should take you to the down loadable manual for that head unit.
7helpful
Diagram for adaptor ks-u57
There's nothing to it--look 'inside' the connector and you'll see three metal contacts close the metal connector (somewhat similar design as a USB jack). The center is common for the line out, and the left/right are the positive for the left and right channels. The metal connector itself is not part of the circuit.
So if you were connecting RCA jacks to it, the outer ('negative') of both RCAs connects to the center contact on the KS-U57, and the center ('positive,' or 'signal') of the left and right RCAs go to the contacts bracketing the center.
KS-U58 and KS-U57 are wired the same.
1helpful
JVC CarAudioModel KS-RT404 lost rear panel containing connections
http://files.ddrservice.info/Audio/jvc/ks-rt404.pdf
This link will take you to the manual. On page 7 you will find the connection Info. you need.
Where does th JVC KS-SRA 100 power cord wire into. It says 14V DC outlet. is this the fuse box or a wire on the JVC receiver. I can get satelite reception but sound
Power cord that goes to fuse box to provide power to unit. Yellow to 14V DC and black to Ground / car body.
J-Bus connector goes to receiver to amplify sound that goes to speakers.
Hit "add a comment" for further query / info.
Thanks.
2helpful
Color code for speaker out on a JVC KS R140 car casette player
White - left front
Grey - right front
Green - left rear
Purple - right rear
Yellow - memory power
Blue - remote power (power ant, amp or eq power)
Wiring Harness for JVC KS-R127
I can uually find those on ebay for a few bucks. You will need to count the number of pins then go shipping.... Also look for a seller called cali car stereo if they dont have it listed they probhably have it at thier store..
Sep 08, 2007 • JVC KS-R127
Top JVC GPS Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a JVC GPS Expert? Answer questions, earn points and help others
