Maytag MAV8557 Top Load Washer Logo
Posted on Jun 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Washer ran all over the floor after filling up and didnt stop filling
Mike
Level 3:
  • Master 4,383 Answers
  • Posted on Jun 11, 2011
Mike
Master
Level 3:
Answers
4383
Questions
Helped
1260243
Points
17064
Well, there are two main possibilities: Inlet valves and pressure sensor system. to test the inlet valves, turn off the machine, do they stop? Dirt can keep them open.
If power off stops the water, I suspect the pressure system. There is a component outside at the bottom of the drum that measures the water volume, using pressure. This collector component sometimes gets clogged with detergent. If it is open, test the transducer at the other end of the plastic hose. The system is designed to stop the power to the inlet valves when the pressure builds.
Testimonial: "thanks, the hose came off of the water pressure sensor"
My washer want stop filling up and when I should the machine off the water runs in the floor
Good Afternoon Friend,
I understand that your Frigidaire washer, model# FWS833A, will not stop filling. I see that you shut the machine off and the water runs onto the floor. I suggest shutting the water off at the inlet. From there I would contact your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why the water will not stop filling your washer. Hope this is helpful.
-Best Regards-
WP
Washer won't stop filling
Does the water stop filling if machine is unplugged? If yes, bad water valve inside washer.
If water stops when unplugged, may be a faulty pressure switch or airdome hose came loose from switch - located in control panel - water level switch.
If water keeps filling and never overflows onto floor - likely that water is siphoning out drain hose. Raise drain hose higher or allow an air break at the drain hose exit.
My washer fills then draind right away, so water r...
Check that the drain hose is not below the water level. If it's too low the water has no reason to stay in the machine...If the water is pumping out, you have a technical problem and will probably need a tech...Good luck....Nomess
Hi... My washing machine... samsung front load. will stop in the middle of the wash and beep and flashes nF. We had bought the floor model and when we got it home realized we didnt have a manual... I can...
nf is the failure code for [no fill].check your water valve screens for a mineral buildup/blockage.they are where the fill hoses attach to your washer.make sure water is present at washer[run the water from each hose into a bucket].i live in ohio its 0 degrees out side now.i did't know it but there was an air leak near my dishwasher drain hose in the house and water froze in it blocking the drain.i hope this info helps you fix this washer, God bless ,tom
3answers
Washer continues to fill after full, then spills all over floor until manual shut off
This is an indication of a pressure switch malfunction. Post back with your washer brand name and model number and I can tell you how to check it.
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
