Good Day!
Please check your TV inside if the CRT tube is having heater or light in tube..
I think you don't have a heater or light on the CRT tube because you don't have a picture..
So you have to do is check the heater supply on the CRT socket it should have 6vac test it using multimeter (range in AC) after that trace the line from the CRT socket going to the secondary of the ply-back when you trace the line there is the resistor connected through please replaced it with the same type,ratings and value.
Thank you and good luck
