Soap injectors are easily clogged or will not work because of design (air leaks will prevent chem from entering if chemical has to be drawn uphill) . They work with siphon action and will only work with very little pressure at the tip but good volume. If your siphon valve has the ball in place, however is missing the fine spring that holds the ball against seat (fine spring holds ball aginst intake fitting), the soap will not be sucked into stream. If ball and spring are in place, try elevating the soap container higher than the opening of the port (gravity feed may help to feed soap into system) . May be better to use an aftermarket downstream injector valve sold on ebay or many outlets. Cost about $20 but work better and are adjustable to save on soap. Search ebay for "Chemical Injector For Pressure Washers" or google "Pressure Washer Downstream Chemical Injectors" Various prices but lower price units work better than factory. Good luck
Your heading is for chain saws but going by your problem I'll assume you are having problems with your pressure washer. The most likely reason your washer won't draw the soap into the water stream is you are using one of the high pressure tips, usually red, white or yellow. The only way the soap system will work is if you use the low pressure, soap tip which is black. Another thing to check is the soap line and pickup filter to make sure they are clear and allow the solution to be picked up.
Take the small soap line off and make sure you can blow air through. Where the line attaches to the soap container make sure the hole is clear if not take a streight pin and make sure the pin goes in the hole easily.
Most pressure washers introduce soap into stream of water by the siphon method. In order for the system to siphon the pressure tip must be changed to one with large opening. Once the large tip is install, the fast moving low pressure water thru the hose and wand will draw-in soap. With the pressure tip installed soap will not be drawn-in. To spray soap and water under pressure use a large container (larger the better like clean 30 gallon trashcan) and fill with clean water and measure of liquid detergent. Use short water hose from with-in container and connect to pressure washer as normal. Keep checking water level so that washer will not run dry. Most pressue washers will **** water in quickly from container, however you can pre-fill the water hose with water to speed things up. Trailer mounted pressure washers use a very large container for water. You can estimate how log the pressure washer will take to use the water by checking the gallons per minute rating of your machine. Good luck
the pick up line sounds like it is blocked...probably by soap that has hardened in the line...take it off and clean it with hot water....squirt the garden hose up the line to help free up stuck gunge in line..take time with it and all will be fine.....remember to run clean fresh water thru soap pick up line after every use.
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Dear johnny_river,
In general there are many causes why soap is not sucked. In a domestic and various other machines the soap is only sucked in low pressure. So one thing you can try is remove the nozzle or the complete lance from your gun. This will give a low pressure. If you attach a pipe directly to the machine soap inlet, and soap is not sucked, than the soap valve is "stuck closed" with soap. It is important that one must work with fresh water after using soap. This to flash the system from any soap left. So in a few words attach a pipe directly to the nipple at the machine and use low pressure. Important , you do not have to use soap to test....use fresh water. If this works( which it should)...than service the flow control tap or change it altogether.
Regards,
fulltech.
i would quit using powder soap and use the HE soap.I would take the soap dispenser out and clean it out and also clean out behind the dispenser.run just water thru machine or try washer magic to clean out the machine.you can find washer magic at most home depots or lowes or even a appliance parts house.
Most detergent injectors work by the venturi system. That is that the detergent is drawn into the stream by the forward flow of the water thru a very narrow port after the water passes thru the pump. This system works best when the pressure at the tip of the wand is low. Trying using a very large tip to draw in and apply the detergent, then remove injector and rinse with high pressure. Not good for the pump but to apply soap reliably under high pressure the soap needs to be injected through the intake of the pump. enjoy
going to try this
