Toshiba Satellite A75-S209 Notebook Logo
Posted on Jun 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wanted Toshiba Satellite A75-S209 17"
Anonymous
Level 3:
  • Master 675 Answers
  • Posted on Jun 11, 2011
Anonymous
Master
Level 3:
Answers
675
Questions
0
Helped
176191
Points
2146
I had an old thinkpad that i needed a screen for...i believe I ordered it off ebay...and it was under 100 dollars...go to ebay and try it
How do I do a complete restore on a Toshiba Satellite A75-S209
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the system recovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
Toshiba laptop satellite A75 dim screen
The used inverter maybe faulty. The inverter supplies high voltage to the CCFL lamp in the LCD screen, the CCFL lamp provides the backlight.
LCD screens and Inverters are available from this WEB site.www.lcdparts.net
2answers
Screen black & with no power
hi there,
you can follow this instruction and try to your laptop to resolved the problem.
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with Toshiba Satellite M35X and Toshiba Satellite A70/A75 notebooks. If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it’s still under warranty, it would be fixed at no charge to you.
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. Toshiba Satellite M35X and Toshiba Satellite A70/A75 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system board with a magnifying glass. In most cases you get the power problem because of a bad connection between the DC jack and the system board, you’ll see a crack between the DC jack connector and the system board.
Here is an example of Toshiba Satellite M35X power jack. The crack occurs between the DC jack pin and the system board.
satellite-m35x-crack.jpg satellite-m35x-contact.jpg In some cases the connection is good, but the DC jack is bad itself. You can find a new DC jack for Toshiba Satellite M35X and Toshiba Satellite A70/A75 laptops here. Search for DC jack M35X or DC jack A75.
How to resolder laptop power jack yourself.
UPDATE:
Sometimes, after you replace the jack, you can see that the system board doesn’t get power at all. The battery will not charge and the power LED will not light when you plug in the AC adapter. So, here’s a possible explanation.
When a connection between the positive pin and the motherboard breaks (cracks), the power jack gets loose. You can feel it when you plug in the adapter plug. A loose power jack can damage the trace inside the hole in the system board. Take a look at the picture.
power-jack.gif As you see, the positive pin goes through the hole in the system board and you solder it on the top side. Right? What if the trace between the top side and the bottom side is broken somewhere inside the hole? I’ve seen it before a few times. In this case everything looks nice and clean on the top side. When you plug in the AC adapter, you get normal voltage readings between “+” and “-“ pins on the top side, but the power DOESN’T go to the motherboard at all, because there is no connection between the top and bottom sides. Test with a multimeter if there is a connection between the top and the bottom.
If the trace inside the hole is broken you still can fix it. You can run a wire to connect the top and the bottom sides. Be careful not to short something on the board.
Update:
Here’s another solution to fix the power jack problem, it shows how to relocate the power jack outside the laptop base. Check it out here: Toshiba Satellite A75 failed power jack workaround.
When you repair a loose power jack, it’s a good idea to check the jack on both sides of the motherboard. When you remove the top cover from a Toshiba Satellite A70/A75 laptop you can see only points where the jack is soldered to the motherboard as it shown on the second picture in this post, but you cannot see the jack itself as it shown on the first picture.
Removing the motherboard from Satellite A70/A75 laptop is a good idea because the jack itself might has a broken “+” pin, as it shown on the picture below. If the “+” broke off the base, you’ll have to replace the jack.
Adding memory to Toshiba A75-S211
you buy the memory here for a great price or anywhere online instructions are on the page
it replaces the 512
http://cgi.ebay.com/1GB-DDR-333-for-Toshiba-Satellite-A75-S211-Memory-RAM_W0QQitemZ250353026446QQihZ015QQcategoryZ158897QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
  • Memory Card for Toshiba Satellite A75-S211 Memory RAM- Designed and Optimized
  • Toshiba Satellite A75-S211 Memory RAM Memory Upgrade -Easily installed
  • More Memory Equals - More Speed for your APPS
  • The Toshiba Satellite A75-S211 Memory RAM has a memory card slot or slots, that allows you to add more memory to your Toshiba Satellite A75-S211 Memory RAM, giving you enhanced performance and speed. You will see the Immediate speed increase in your computers performance.
    Stop waiting for programs, and functions to happen, STOP WAITING!!! Start enjoying technology as you should.
    We work directly with our memory card manufacturer to insure perfect compatibility with the Toshiba Satellite A75-S211 Memory RAM. Only using the highest quality memory chipsets for our memory cards, so you are assured compatibility and performance. All of our memory cards are Designed and Optimized for Toshiba Satellite A75-S211 Memory RAM . Technical specialists have personally verified our memory cards compatibility with the Toshiba Satellite A75-S211 Memory RAM.
    Worry Free Installation: Just Follow these Steps Desktop and Laptop instructions below.
    Desktops
    1. Unplug Power cable
    2. Remove Case
    3. Slide memory card in Open slots- the memory card will only fit in one way
    4. Snap the side clips in place
    5. Close Case and Power Up
    6. You are ready to go.
    Laptop
    1. unplug and remove Battery from laptop
    2. Open memory compartment on bottom using Philips screw driver
    3. inset memory in open slot, if no open slot remove current memory by pinching metal clasp on side of memory
    4. Close compartment and power up you are off and running.
    1helpful
    How do I replace a keyboard on a Toshiba Satellite A75-S211 laptop computer. I cant see any way to get it out. Also, the power button needs to be repositioned... same problem.
    How to take apart Toshiba laptops. Instructions with pics ... 10 posts - Last post: 21 Mar 2006 Toshiba Satellite A70/A75 Toshiba Satellite P25 Toshiba Tecra A1 .... Toshiba Portege 3500 Tablet PC manual. How to remove and replace the ...
    www.thinkcomputers.org/forum/showthread.php?t=632 - 76k -
    A brobblem with my chrger
    Here is the replacement Toshiba Satellite A75-S209 A75-S2112 AC Power ..
    Part number: PA3290U-2ACA, or PA3290E-2ACA
    Toshiba Satellite A75-S2112
    You can get a replacement screen here. http://base.google.com/base/a/309518/D787066591146521512
     Installation can be tricky.
    Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/larry_1fe25e09c54eece2
    Sound driver
    Could not find sound drivers for your computer but this is the sites searches you might want to try.One of theses sites could also work for the same drivers you are needing.
    Toshiba Satellite A75 Driver
    Detect Drivers I Need Updates
    Drivers For Toshiba A75 S125
    Good Luck/Please dont for get to vote.Thank You.
    Top Toshiba Computers & Internet Experts
    ExpressFiX
    ExpressFiX
    k24674
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
