Hi guys i found reset button in whirlpool chrome model split 1.5 ton just you lift the door of ac then you look carefully at the top of right there is a warnig door no need open that just above a button like thing in a hole just press it when ac is on
You can find the reset button on its remote. If you watch carefully you can see a small hole on the remote. There is the reset switch. using a ball pen press the button inside the hole.
ok
SOURCE: where is reset button located
Look at your remote carefully. There is a bal pen type push to reset filter button on the remote. Depress the rest button and it should reset. Also on the contol panel you can also reset it by depressing the mode and the UP temp arrow buttons for 5 seconds.
Thanks for choosing FixYa.
Kelly
Look real hard on the remote. There is a mini "use a ballpoint pen" push to reset filter button on the remote.
Electronic control panel: (not all models)
Hold the mode button and the Temp Up arrow depressed for about 5 seconds. It should display the temp and the FL should disappear.
Kelly
