SOURCE: go about getting operational anual for fish finder humminbird
I found what you are looking for. Go to: http://www.humminbird.com/support/FAQ.aspx?faqid=72
You can download the operating manual.
SOURCE: need a user manual for a Humminbird fish finder,
You get a LCR 40-ID, but not a 4.D. Here is the manual for the 40-ID.
SOURCE: Is there a free downloadable manual for a
type in hummingbird lcr 4000 fish finder manual pdf. it works for anything you want
SOURCE: turns off
The first thing you need to check is if you have sufficient power going to the fishfinder. Take a multimeter and measure the dc voltage going to the display when the unit is off and also on. If this is below 12 vdc this is your problem. You will need to check for loose connections and possibly replace your battery.
If the voltage is good then the problem lies within the display. Unfortunately, you would have to contact Humminbird directly to return the display for repair or purchase a new fishfinder.
SOURCE: Humminbird LCR 4 ID....I lost power cord and am
use the top left and right in the star pattern. looking at the 6 pin layout (center pin included), the pins at 10:00 and 2:00 are for the power.
