Question about Nokia C7 (8 GB) Smartphone
Nokia c7 sim card removal i don't now how ??
  • 1,116 Answers
Insert the SIM card and battery
Important: Do not use a micro-SIM or a micro-SIM with an adapter in this device. This device does not support use of micro-SIM cards, and use of incompatible SIM cards may damage the card or the device, and may corrupt data stored on the card.
Follow the instructions carefully, to avoid damaging the back cover.
Safe removal. Always switch the device off and disconnect the charger before removing the battery.
1 Unlock the back cover release latch, and lift the back cover
2 If the battery is inserted, lift the battery out.
3 Insert a SIM card. Use the diagram printed on the device to correctly align the card.
4 Line up the contacts of the battery and the battery compartment, and insert the battery.
5 To replace the back cover, direct the top locking catches toward their slots, and press down until the cover locks into place.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Posted on Jun 11, 2011
SOURCE:
Sim card not valid
If your Nokia C7 phone displays an error message saying "Insert Sim (or) Sim card not valid" then your phone is probably network locked.
To unlock it,visit the site OnlineGSMunlock.com here they are providing the unlock code at reasonable cost with easy step by step unlocking instructions and unlock it.Then you can use freely any GSM network Sim card.
Nov 18, 2013 | Nokia C7 (8 GB) Smartphone
Phone doesn't boot when SIM is inserted
The Nokia C7 have several issues with the factory installed SIM card reader. Problem can be solved by replacing SIM card reader. Either find your nearest cell phone repair store or buy your own online and replace it yourself.
Jul 28, 2013 | Nokia C7 (8 GB) Smartphone
I don't know what service provder my phone is tied to
Hi.The sim card which you are using in your phone belongs to particular service provider.The name of the service provider will appear after you have inserted the sim card to your phone.Thanks for visiting fixya
Mar 02, 2012 | Nokia C7 (8 GB) Smartphone
Sim card not valied on nokia c7
It's because of Network lock you need to unlock it....
Sep 07, 2011 | Nokia C7 (8 GB) Smartphone
How can i remove my sim card to my nokia c7?
The SIM card is located beneath the battery pack. You must release the back cover latch, lift it up, remove the battery pack, and, then, access the SIM card slot. Please, refer to pages #8 and #9 of your phone's user guide (which you can download from this location, in case you happen to miss it) for further details.
Hope you are able to sort your problems out soon.
Anyway, please, let me know if I can help you any further.
Regards, Carlos
May 11, 2011 | Nokia C7 (8 GB) Smartphone
C7 sim card registration failed
You either need to have the phone unlocked, or match it with a sim card of the same network of the phone. here is a similar forum post i hope it helps. http://www.nokiausers.net/forum/nokia-e71-e72/34629-sim-card-registration-failed.html
May 02, 2011 | Nokia C7 (8 GB) Smartphone
My c7 says phone will restart and then insert sim card at regular intervals
Turn off phone Remove Battery Reseat SIM card Put battery back in then turn it on again. if the problem persist contact nokia
Mar 23, 2011 | Nokia C7 (8 GB) Smartphone
How to remove sim card from nokia c7
RIGHT SOLUTION: To remove the SIM-card, press the SIM-card a bit further down the slot (with another sim-card, a memory card, your nails if they're long enough,...) and then release the pressure. The SIM-card will come out far enough for you to pull it back out.
Feb 28, 2011 | Nokia C7 (8 GB) Smartphone
I need unlock code for nokia c7 movistar spain locked
u can get the unlock code for your nokia c7 model from by using this link http://www.theunlockarena.com/
following instructions makes u easy to unlock your mobile
1 - Switch on your Nokia C7 without any sim card.
2 - Don't bother as to what is displayed on your Nokia C7.
3 - Compose #pw+CODE+1#.
4 - The Nokia C7 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia C7 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia C7
Each Nokia C7 mobile phone has an unique unlock code. You can buy the unique unlock code for your Nokia C7 mobile phone using the form above.
Feb 21, 2011 | Nokia C7 (8 GB) Smartphone
Nokia C7 (8 GB) Smartphone Logo
163 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
