Hello, welcome to FixYa.
A very common problem for Bosch dishwashers of that era. A faulty fill valve...sticking in the "open" position.
It could be debris stuck in the valve, but I wouldn't chance it...just replace it for the cost is much cheaper than a new floor.
This is what to look for...
As long as your model is indeed a Bosch, this info below will be accurate.
Original part is # 425458. It usually retails for about $20 - $30USD at places such as "searspartsdirect.com" "repairclinic.com" to name a couple, if needed. They may be available at your local brick & mortar parts depot/vendors.
**Before attempting to repair the unit please turn off the power and the water supply to the dishwasher...safety first**
If you remove the lower kick plate/toe panel, you will see the inlet valve to your left...
i.e.
Replacing it or to check for debris in the filter/screen at the inlet is pretty straight forward. Here`s how...
1) undo the water line. ( here you can visually inspect the screen in the valve...if nothing noted, you'll likely need to replace it as follows )
2) Remove the two #20 torx screws fastening itdishwasher filling with water when - 156e176.jpg/i>
3) the feed tube to the machine at the dishwasher filling with water when - 5937279.jpg valve and swap it with the new one.
and
Once the new one is in or it's all clear you should be good to go.
Let me know if you need any further assistance, good luck. Thanks for choosing FixYa and good luck. Please take a moment to rate the assistance provided here for you and a brief testimony on your experience here at FixYa is appreciated as well
Regards,
Macmarkus :)
