Code for TV / Sky+remote
Problem: Need Sony manufactures code for the Sky remote.
Solution: Your TV Code for Sony is 0000
1. Turn on your TV.
2. Ensure that the front of your Sky Navigator is closed.
3. Press "tv”.
4. Hold down "select" and the red button together for about two seconds, until the red LED on the Sky Navigatore flashes twice.
5. Press "tv" again.
6. Key in the four digit code for your brand of TV. The LED on the Sky Navigator will flash twice. If the LED illuminates only once, re-check the code for your brand of TV and start again at step 5.
7. Press the standby button on your Sky Navigator. If your TV switches off, press "select". The LED on the Sky Navigator will flash twice. If your TV does not switch off, press "tv", then press the standby button.
Repeat this (press "tv", then standby button) until your TV turns off,
then press "select".
If you are still experiencing problems, please telephone for technical
assistance. you will find the "Technical Help" telephone number by
pressing "services" and selecting "Telephone Numbers".
The help given is based on information taken.... Hoped this has helpd you
Basically it blinks. That is it flashes once after each pause.
