I have the same problem... the sheets stick to the drum... says the transfer roller is faulty but the printer has only done about 6000 copies. The actual model is the 2350.
I have a problem 2350 message...service call 15 xbelt. I removed the unit and replaced it and it did not reset. gjI have a problem 2350 message...service call 15 xbelt. I removed the unit and replaced it and it did not reset. gj
You can't post conmments that contain an email address.
Was the new one new? Check the medal connectors located on the image unit anything medal and clean with alcohol and all connectors on the assy. the image unit goes in reseat properly Third party do not work use OEM
Your error means -
Incorrect pressure by or separation from the transfer belt cleaner
Remedy
1 - Check the Belt cleaner positioning sensor pc9 (located at the rear on the left hand side towards the top when looking from the front of the printer)
2 - Replace the Second image transfer roller pressure/separation
mechanisms.
3 - Check the Image transfer roller pressure contact solenoid SL2 (this sits more in the middle behind the printhead)
4 - Replace PWB-A.
5 - Replace PWB-P.
Problem sorted thankyou very much.
Magicolor 2530 DL says transfer roller--- paper keeps getting stuck!
